Having FUN in the SUN...
![]() Drives: 2022 M6 ZL1 1LE Join Date: Jan 2022
Like I am sure many of you also feel... I am tired of the lack of a proper 6th gear OD for freeway cruising. Has anyone re-geared there trans, or changed the diff ration to compensate?
80mph @ 2,600 rpm is getting old :(
2022 M6 ZLE: GMS Stage.III KONG X.PORT Package + DMS Lid + GMS Rear Bumper Belly Pan + GMS Hood Bracket + GMS Flex Fuel Package + MONSTER Triple S Clutch + XDI.50% Injectors + CLICK FOR BUILD LIST or www.GRIFFIN-MOTORSPORTS.com = 915rwhp 850rwtq + E60 + 15psi
Sarcasm loading --------
You could put a non-1le trans in, 6th is overdrive.
With the power you have the lower ratios will probably work out better anyways. I imagine 1st is completely un-useable.
2018 MBM ZL1 1LE - 652 rwhp, 588 rwtq SAE 2014 CRT ZL1 574 rwhp, 537 rwtq - SOLD 2010 IBM SS Camaro VVT L99 w/ TR6060 swap, 489 rwhp, 444 rwtq - SOLD |
#3 | |
![]() Drives: 2019 ZL1 1LE Join Date: Jul 2022
I've looked around but nobody makes different gearing for the Camaro. |
#4 | |
Hmmm... makes sense... but at my power level, I would be OK with every gear being taller... Thats why I was thinking a ring and pinion swap would be cheaper than a built trans.
![]() Drives: 24 Sliverado 1500 ZR2, 2017 ZL1 Join Date: Feb 2021
Did you check out the 9" differential swap? There may be a ring/pinion gear ratio that suits your needs. Need a big wallet.....
Finally on the way to 1K.....
Switch to taller tires?
#7 |
![]() ![]() ![]() ![]() ![]() Drives: 19' ZL1 A10, w/pdr Join Date: Sep 2014
This was the compromise I considered when I bought the A10, at 80 mph I do 1,900 rpm. I wanted to be able to tour with it and I have. Still the 6 sp would has been nice. I agree try a taller tire it would help some.
#8 |
![]() Drives: 19’ ZL1 A10 / 16’ C7Z M7 Join Date: Apr 2021
I wonder if a TR6070 would swap into a 6th gen. You could put in an aggressive ring and pinion ratio "4:10-4:56" and still have 7th gear for the highway.
#9 |
Probably doesn't like you
Drives: 2022 WCT ZL1 M6 Join Date: Jun 2015
Doesn't fit, iirc someone asked Al O. a while back.
كافر ΜΟΛΩΝ ΛΑΒΕ железобетонное очко Quod gratis asseritur, gratis negatur. There is an unequal amount of good and bad in most things, the trick is to work out the ratio and act accordingly. |
#10 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2024 CT5-V Blackwing Join Date: Sep 2020
https://www.camaro6.com/forums/showthread.php?t=517683 |
#11 |
![]() Drives: Garnet Red / ZL1 1LE Join Date: Apr 2016
I love the gearing of the ZLE! That 6th gear was optimized for the Nurburgring. It goes like a bat out of hell even in 6th gear.
#SAVETHEMANUALS
#12 |
![]() Drives: 2021 1SS 1LE Join Date: Nov 2020
It was my understanding that swapping transmissions was a no go due to computer issues. I wanted to put a ZLE M6 in my SLE and was told that it wouldn't work electronically.
Ken
Follow my build - https://www.camaro6.com/forums/showthread.php?t=594295
#13 | |
I agree 100%... Love how hard it pulls in 6th. But I would be happy downshifting to 5th for some pull, and lugging 6th closer to 1,800 rpm at 80mph.
#14 |
![]() Drives: ‘23 ZL1-1LE Join Date: Mar 2023
I think you may be under the impression that the ZLE is a wide ratio trans. It’s the opposite. 1st gear is far taller than a standard ZL1. It has a specific close ratio box for road racing. Gears are tightened up including both overdrive gears (5th and 6th). Coming out of a wide ratio trans, I absolutely love this box. I’ve never had a manual trans that works as good as the ZLE box and the gearing is awesome. I do understand the grass is always greener on the other side. I was on the other side for twenty years, lol. Perfect trans inmho.
