Old 05-15-2024, 01:24 PM   #1
BlackbeastSS2
BlackbeastSS2's Avatar
Drives: 2019 Camaro 1LE Shock Candy
M6 with Bias Ply
I recently picked up a pair of ET Street R and after reading more stuff on Bias Ply I am ready to get a set of Bias Ply after running the R’s.
I have 17 inch x10 in the rear so not much choice for 17 inch Mickey Thompson tires, in fact only one 17 inch. So I guess I will be running a four corner square in the future. What are you guys running for Bias Ply and any advice would be appreciated.
Did you find any difference and better times?
LT4 1.7 Supercharger snout ported & 100% Meth
103 Katech TB, KATECH Custom Heads, DSX In-line fuel
TSP Headers, Spec P Super Twin Clutch, TSP EL C7 CAM
Diamond Piston & Manley Rods, Roto Fab Big Gulp
BTR Push Rods,LS7 Lifters, ARP, FI Chiller, Kirkey Seats
SJM Line Lock, Hurst Pistol Grip. 747/739 RWHP street tune - 821/794 RWHP track tune 101 octane.
2014 Mini Cooper countryman S All4 M6 daily driver
BlackbeastSS2 is offline   Reply With Quote
Old 05-15-2024, 02:25 PM   #2
6spdhyperblue
Drives: 2SS 1LE
Not DOT right?
Then really the 28” Hoosier is the one. I think it’s like 27.5” but used on most of the bolt on record cars.
You need a skinny tho.
Old 05-15-2024, 05:50 PM   #3
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Make sure the skinnies are bias ply too then. Do not mismatch them.
Old 05-15-2024, 06:44 PM   #4
BlackbeastSS2
Roger on that and aware of it. Had skinnies on my last build and honestly did like the feel on the track. Not looking to go for a record run, safe and consistent is what I am after. I see guys in the 8’s and that’s a lot of hard work. My car is forsure a 10 second car and if I get into the 9’s I will be happy. The Bias Ply will be easier on my drivetrain and that’s what I want for a manual. The wheel hop was violent last weekend.
Old 05-15-2024, 08:39 PM   #5
jlaudio11
jlaudio11's Avatar
Drives: Chevy Camaro
I’ve had decent results with the Hoosier quick time pro bias ply. It is a soft sidewall tire. If you’re not running a class requiring a dot tire I would probably go with a Hoosier c07 stiff sidewall slick.
'20 Camaro LT1
Twin 67/62 turbo 401(L8t) Texas speed forged piston & rod, BTR stg1 turbo cam, holley ultra lo, port injection, circle d 3600 stall, et street r’s on racestar recluse wheels.
1.33 3.75 5.75@122.98 1/8 pb 9.04@141 1/4 pb technically
'94 Camaro Z28 6mt cc306 cam, 4:10's, longtubes with x pipe, otr intake
jlaudio11 is offline   Reply With Quote
Old 05-16-2024, 07:30 AM   #6
BlackbeastSS2
Thanks for the input but not doing a 15 inch conversion. Looking to stay with 17 inch rim, so my tire selection is not that big for bias ply.
Hoosier & MT only currently have one 17 in. The Hoosier is a 11 inch rim and MT is technically 9.5 but 10 will do. So it’s MT for now unless someone advises differently.
Old 05-16-2024, 07:44 AM   #7
6spdhyperblue
Drives: 2SS 1LE
The MT, if you’re looking at the DOT, is very very tall. Like 28.5”
with boost it might work. I ran it and it felt great driving it track and back. The launch was super soft on the driveline. Just way to tall and bogged the motor down on a simple NA bolt on car
Old 05-16-2024, 08:48 AM   #8
jlaudio11
jlaudio11's Avatar
18157http://https://www.summitracing.com/parts/hoo-18157
http://https://www.summitracing.com/parts/mnh-mhr-173
http://https://www.summitracing.com/parts/phx-ph187
'20 Camaro LT1
Old 05-16-2024, 12:53 PM   #9
BlackbeastSS2
9.28 nice, I guess your happy with the Bias Ply. Part of the puzzle. After trying them what’s your take away on them.
Old 05-17-2024, 10:58 AM   #10
jlaudio11
jlaudio11's Avatar
I went bias ply to be easier on the drivetrain in general. I also run alot of daily driver classes that require a dot tire. That’s how I ended up with the quick time pros, they’re popular in the no prep world. I actually need to replace the current set, they still have grooves but I have killed the sidewalls on them. They wad up on launch now more than just wrinkle. I’m currently considering the et street r bias ply or maybe even the r radial. The Mickey Thompsons are supposed to have a stiffer sidewall. Current weight of 3960lbs with driver and the power I’m trying to leave, hoping a stiffer sidewall will hold up better.
If you’re always running front side prepped track, I would think about any of bias ply options would do just fine for you.
'20 Camaro LT1
