![]() ![]() ![]() ![]() ![]() ![]() Drives: 2019 Camaro 1LE Shock Candy Join Date: Mar 2016
Weld wheels and MT ET Street R problem.
Well I put my tires together in the garage today and surprise surprise. One step forward and two steps back. I was looking so forward to put them on my car today. Oh well shit happens.
Guess they couldn’t hold the street PSI of 28 pounds.
LT4 1.7 Supercharger snout ported & 100% Meth
103 Katech TB, KATECH Custom Heads, DSX In-line fuel TSP Headers, Spec P Super Twin Clutch, TSP EL C7 CAM Diamond Piston & Manley Rods, Roto Fab Big Gulp BTR Push Rods,LS7 Lifters, ARP, FI Chiller, Kirkey Seats SJM Line Lock, Hurst Pistol Grip. 747/739 RWHP street tune - 821/794 RWHP track tune 101 octane. 2014 Mini Cooper countryman S All4 M6 daily driver |
Moderator
Wow, guess it’s just a bad tire. That should do that all day long normally.
^Agree...that is simply a defective tire.
![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro 1SS Join Date: Aug 2016
Agree with this, because I had that same model and size tire, pumped it up to 32psi for the street drive, and had nothing like that appear. You just happened to get a defective one is what seemed to happen here.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2SS 1LE Join Date: Aug 2013
Not saying this happened, but there is a warning to not exceed max pressure to seat the bead.
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2020 Camaro 2SS A10 Join Date: Jun 2018
Am I the only one who wants to poke it with a stick?
#7 |
There are lots of complaints on the web about poor-quality MT tires. My last pair had flat spots. It seems like every pair I've owned vibrated at speed.
2020 ZL1LE A10.
LME LT4 390 short block, CID Heads, Kong E2650, FBO. 15" conversion, Nitto 555Rii or MT ET Street R or Toyo Proxes RR. 100 octane: 1045hp/1055tq. 100 octane + Alky MAF Meth (1) 10+: |
#8 |
Air pressure on machine was set to 28 psi.
#9 |
![]() ![]() ![]() I am waiting for the tire place and his supplier to give me an answer to warranty. IMO should be a no brainer and they should replace the tire. Wasn’t even mounted on car or driven. Hopefully common sense prevails.
#10 |
Unfortunately they’re fast tires and offer models and sizes others do not. :(
#11 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: like an old lady Join Date: Jun 2012
that is an isolated bad tire incident. hoosier makes comparable tires, as well.
you ever get any time slips with this setup?
#12 |
Up here in Toronto, Saturday was 1st day opening at the track. It was cloudy and cool, about 51F. The prep was not good and lots of spinning in 1,2,3 on shi_t nitto tires. The plan was to use the Mickeys but that didn’t happen. I had lots of wheel hop as well. Six passes and shut down 3 of them. Best time that day was only 11.6 at 127 with spinning and short shift. Need to dial this car in, so need more runs, warmer temps with sun and better tires on.
#13 |
Even on a 1LE, I’m surprised you get wheel hop at 17-18 psi
Non 1LE SS cars do not wheel hop ever in my experience. I would see if you can get your alignment closer to an SS.
#14 | |
Could be this to, launching the car I am currently only leaving at 2800 rpm. (That’s not high) “ Hard launches - 'stick cars are most prone to it, so avoiding clutch dumps @ high rpm is required to avoid it. It requires feathering the throttle to get wheelspin w/o inducing wheelhop.”
103 Katech TB, KATECH Custom Heads, DSX In-line fuel TSP Headers, Spec P Super Twin Clutch, TSP EL C7 CAM Diamond Piston & Manley Rods, Roto Fab Big Gulp BTR Push Rods,LS7 Lifters, ARP, FI Chiller, Kirkey Seats SJM Line Lock, Hurst Pistol Grip. 747/739 RWHP street tune - 821/794 RWHP track tune 101 octane. 2014 Mini Cooper countryman S All4 M6 daily driver Last edited by BlackbeastSS2; 05-14-2024 at 08:21 AM. |
