![]() Drives: Chevy Camaro ZL1 1LE Join Date: Aug 2023
ZL1 1LE Rear Seat
Hello, I still feel like I am new to this as a 2023 ZL1 1LE owner. I know the rear seat fold-down is not available on my car for weight reasons. I saw videos on how to cut some fabric to gain access to the latch to manually unlatch the seat and fold it down. I tried it, I do not have a Latch. I would appreciate any information about how to just remove the Seat Back-Rest completely. Any other thoughts are appreciated. Thanks!
Have you tried the "secondary hole" method on the backside of the rear seat, accessing it from the trunk?
I did see videos to cut fabric from the trunk side to gain access to the Latch, then manually unlatch it. I did try that. I cut fabric on the Trunk side where the Latch would be. There is no Latch. I think this is a 1LE thing.
![]() Drives: 2022 Wild Cherry ZL1 1LE Join Date: Mar 2021
Hello there!
Yes, folding down the rear seat on ZL1 1LE is unnecessarily complicated... I've been able to fold it by randomly poking a long metal rod (screwdriver extension bar in my case) through the little flap at the top. I wasn't able to do it with my finger (or was too scared I'd end up cutting myself trying haha) Without completely ripping the back of the seat's fabric, I wasn't able to understand the mechanism, nor was I able to attach some wire to make it easier next time around ![]() ![]() Geoff |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2024 CT5-V Blackwing Join Date: Sep 2020
I would just remove the backseat if I owned a ZL1 1LE, its a track package therefore doesn't need the backseat. Sounds like a hassle to keep it installed anyway. Save even more weight with it removed.
![]() ![]() Drives: Chevrolet Camaro ZL1 1LE Join Date: Oct 2021
I've done this numerous times.
In the trunk you can get to the center of the back seat where there's a little piece of cloth covering the latch assembly. I've reached in and used a long socket wrench extender to press on the metal latch assembly and it works. |
#7 |
![]() Drives: 2017 Camaro ZL1 Join Date: Feb 2024
So if the seat is there....and the latch is there, but covered.
Where is the weight savings ???
#8 | |
Geoff |
#9 | |
![]() It should be the same, except for the attached strap that is missing on the ZL1 1LE for some weird reason.
#10 |
![]() Drives: 2021 ZLE & 1972 Camaro Join Date: Oct 2021
Don't cut the fabric, it's behind the flap that's below the visible hole. Pull the flap down and prod around in there. You'll feel it. You don't need a tool or anything, although if you have shorter arms you might not be able to reach it.
#11 |
Sarcasm loading --------
I read elsewhere on this forum that the ZLE seat doesnt have the bracing the regular seats have.
2018 MBM ZL1 1LE - 652 rwhp, 588 rwtq SAE 2014 CRT ZL1 574 rwhp, 537 rwtq - SOLD 2010 IBM SS Camaro VVT L99 w/ TR6060 swap, 489 rwhp, 444 rwtq - SOLD |
#12 | |
![]() Drives: 2022 ZL1 1LE Join Date: Jan 2021
This video was posted on the forum years ago. Maybe it will help
2022 Red Hot ZL1 1LE
1972 Chevy Nova Sold: 1997 Z28 Camaro 2000 Corvette |
#13 |
Thanks to everyone for commenting. What is interesting, is my 2023 does not have a flap. That was the very first thing I looked for. So I made a cut in the fabric. I would be surprised if they made a design change, but I do not know what else it could be....??? No flap for me! Everything else I have seen says you have to lower the seat back to remove it, which I cannot do... so I am stuck!
