Old 05-06-2024, 04:18 PM   #1
Uncle
Drives: 2023 SS w/ 1LE
Stuck in Tour Mode!
Hello!
I have a 2023 1SS with 1LE and recently upgraded the factory speakers (which were rental car speakers/low quality) with all new Alpine speakers, a JL Audio amp, and AXDSPX-GM30 DSP. (digital signal processor)
Now the Camaro is stuck in “Tour” Driving mode and I cannot cycle thru to the other driving modes (Sport is my preferred) nor can I turn off the Traction control button (so that I can peel out and do donuts)
I am hoping that this is an easy fix. The shop that installed the DSP thinks its something with that and an adjustment needs to be made or software change, but I wanted to check here also.
Please help!
Uncle is offline   Reply With Quote
Old 05-06-2024, 05:37 PM   #2
ChibbMD
Drives: 2022 SS 1LE
If you go into the mode settings on the head unit (not using the switch) can you change it there?
ChibbMD is offline   Reply With Quote
Old 05-06-2024, 05:55 PM   #3
2SS Capt
2020 Shadow Gray 2SS
2SS Capt's Avatar
Originally Posted by Uncle View Post
Hello!
Please help!
Did they touch anything on your center console? Sounds like they may have unplugged those switches and forgot to plug them back in...
Old 05-06-2024, 06:01 PM   #4
CalgaryZL1
CalgaryZL1's Avatar
Drives: 2020 Chevy Camaro ZL1
That’s if the head unit is responsive.
Old 05-06-2024, 06:07 PM   #5
Uncle
Thank you all for your replies.
I just went to the garage and tested the head unit and I was able to cycle thru the different modes (engine sound/steering/suspension). But on the dashboard the indicator was still stuck on the blue "Tour" indicator box. Additionally, the Traction Control Button (to turn off/disable) still did not work. Obviously I want to have that capability (for fun driving).
Old 05-06-2024, 06:32 PM   #6
SamSmoothCastel
Drives: 67 Orange Mustang Coupe
unplug your battery. Hard reset may fix it.
SamSmoothCastel is offline   Reply With Quote
Old 05-06-2024, 06:34 PM   #7
2SS Capt
2SS Capt's Avatar
Did you see my reply?
Old 05-07-2024, 12:35 AM   #8
RIPws6
RIPws6's Avatar
Drives: 2019 2SS Riverside Blue
You shouldn’t be dealing with any of this. Take it down there and make them fix it.
RIPws6 is offline   Reply With Quote
Old 05-07-2024, 05:37 AM   #9
Spaceme1117
Spaceme1117's Avatar
Drives: 2017 Camaro SS, 2011 Corvette GS
Probably this.
Spaceme1117 is offline   Reply With Quote
