Old 05-06-2024, 04:05 PM   #1
Osbornsm
Drives: 2018 SS 1LE
Arrow Can you full-send a patched tire?
Hey all,
I had a track day at road america, which was awesome. Until i started the car for the 2nd session and *DING 15 psi low on one tire.
So my track day was ruined... still got a PR in the 1st session!
Question
Can you track a tire that has been plugged/patched at center tread?
Thanks kindly,
~ The mgmt
2018 Camaro SS 1LE - 2011 370z - 2004 VW R32 - 2000 Civic Si
Mods: Rotofab, Nick Williams 103mm TB, MSD IM, Kooks 1 7/8
Results: 470 hp / 447 tq
Osbornsm is offline   Reply With Quote
Old 05-06-2024, 04:30 PM   #2
Slurpee
Slurpee's Avatar
Drives: 2020 ZL1 A10; Shadow Gray Metallic
I had a nail dead center in a slick first session during a 3 day weekend. Plugged it and ran the plug for the whole weekend. Held air until the last session of the day. Junked the tires after that event.
Slurpee is offline   Reply With Quote
Old 05-06-2024, 07:34 PM   #3
VaporPressure
Drives: '18 ZL1 1LE
I've run a few sessions on a plugged Pirelli. Didn't have any issues but didn't keep it after the weekend.
VaporPressure is offline   Reply With Quote
Old 05-06-2024, 07:37 PM   #4
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
never had any issues lol just as long as its not on the sidewall
Old 05-06-2024, 09:06 PM   #5
RoaringV8
Drives: 2017 HBM Camaro SS 1LE Camaro
Personally, I wouldn't trust running with a plugged tire. I've been running a tire that's been hot patched for a couple years and probably 6 or so track days. Never had an issue and tire has always held air very well. My two cents.
RoaringV8 is offline   Reply With Quote
Old 05-06-2024, 09:27 PM   #6
nikerret
Drives: 2014 Ford F-350
This is a plug:
This is a patch:
This is a “patch ‘n plug” or a “plug patch”.
Plugs are for temporary situations where you just need to get to the next service department.
Patches are fine, but rely heavily on proper prep and application. This is okay, but not preferred and I have seen them fail.
The plug patch is the way to go. If it’s properly applied, that part of the tire is actually tougher than the areas around it. I worked over a decade in rural law enforcement. We ran a lot of gravel and a lot of interstates and everything in between. I’ve run tires with up to three of these at sustained speeds over 130 MPH and off-road. I’ve never seen or heard of one failing.
To properly apply, the foreign object is removed, then the hole is drilled out creating a clean break in the cords. The inside of the tire is burnished around the hole and scraped clean. Rubber cement is applied and lit of fire. When the fire goes out, the plug patch covers are removed and it’s pulled through. The adhesive on the plug patch connects with the hot, melted rubber cement on the scraped tire inner. It’s then rolled flat and the dome cover is removed. Sealant is then applied over the plug patch. Final step is to pull the plug side as far as you can on the tread side and cut as low as possible. The plug patch will then wear with the tread.
2024 Red Hot 2SS 1LE w/BCD, PDR
2014 F-350 Crew Cab Cassis Cab Dually 6.2L w/4.30
2014 Hyundai Elantra GT
1995 Buick Roadmaster Estate
nikerret is offline   Reply With Quote
Old 05-06-2024, 09:59 PM   #7
5.M0NSTER
5.M0NSTER's Avatar
Drives: 2018 Camaro 1SS 1LE
Yessir. Send it!
5.M0NSTER is offline   Reply With Quote
Old 05-07-2024, 06:38 AM   #8
Spaceme1117
Spaceme1117's Avatar
Drives: 2017 Camaro SS, 2011 Corvette GS
Probably not a good idea to track a car on a tire that had been patched or plugged.
But likely won't cause a problem.
Spaceme1117 is offline   Reply With Quote
Old 05-07-2024, 07:58 AM   #9
sr71bb
sr71bb's Avatar
Drives: 2019 Camaro Z-28
According to DISCOUNT TIRE, YES.
Originally Posted by Osbornsm View Post
Hey all,
Question
Thanks kindly,
~ The mgmt
2019 SS 1LE BIG NA A10
Eagles Canyon Raceway 2.7 CCW Below
https://youtu.be/c9M5UHDftcA
4-15-23 at SCCA TT U1 Class
MEGA Thread on THIS car:
https://www.camaro6.com/forums/showthread.php?t=602092
Retired Cars BELOW:
1973 Camaro, 1969 Camaro, 1969 Camaro SS RS
2010 Camaro SS with 1000HP F1R, 2019 ZL1 1LE A10
sr71bb is offline   Reply With Quote
Old 05-07-2024, 05:23 PM   #10
SSEssence
Instagram: Sangstah
Drives: 2019 Camaro 1LE
Properly applied patch, no issue on track.
SSEssence is offline   Reply With Quote
Old 05-09-2024, 11:29 AM   #11
TransamGTA350
Drives: 2023 Camaro SS1LE
Had this same scenario happen to me this past Saturday at Thompson Motorsports Park in Connecticut. 3rd lap of my 1st session, 0psi in the right rear tire. Made it in to pit and parked in the paddock without the tire coming off of the bead. Must have ran over some debris on the track, but it wasn't in the tire, just a hole. Pulled the wheel/tire off, one of the event staff brought it to a local tire shop where they dismounted the tire and did a patch/plug. Put it back on, adjusted air pressure and was back track for my next session. Ran 5 sessions with the patched tire, no issue and going to Palmer in MA on Monday for another track day with the same tires.
You should have no issue with a properly done patch/plug.
2023 Camaro SS1LE
1989 Trans am GTA
TransamGTA350 is offline   Reply With Quote
Old 05-15-2024, 06:47 PM   #12
Osbornsm
Drives: 2018 SS 1LE
General concensus: Do not send.
I've asked around and places and people say they do free repairs, but no guarantees in sight.
Bought a used tire from eBay and replacing the plugged one. 🛞
Thank you for the input,
- Sean
