![]() ![]() ![]() ![]() ![]() Drives: 2012 Shelby GT500 Join Date: Jan 2020
Question for those who went SS —> ZL1
Is the power discrepancy noticeable at lower and normal highway speeds (35-85 mph)? If it’s not that noticeable is it very noticeable from say 60+ mph? I’m aware that horsepower discrepancy mostly starts to show the faster a car is going. Trying to figure out if it’s worth upgrading to a 650+ hp car or not. Like if it’s not that noticeable down low or from say 60-130 mph (there is a half mile event near me) I may just put off upgrading.
I also want to make it clear I don’t actually care much about the car accelerating faster. I know a zl1 accelerates faster the faster you’re going versus an SS. What I want to know is if zl1’s shove you back into the seat MUCH harder than your SS did. That’s what I mean when I’m asking if the power discrepancy is more noticeable because I know acceleration wise from lower speed traction will be a problem at lower speeds. If you went manual to auto please provide that info because I believe there is a noticeable difference in a10 acceleration versus manual.
2012 Shelby GT500 with VMP Gen 3R.
Prior: 2023 Camaro 2SS 1LE 2016 Camaro 1SS 2007 Mustang GT 2008 Civic Si |
![]() Drives: 2017 ZL1 Join Date: Mar 2022
Hard to read what you are trying to say but-
Yes, going from a cammed c6 with 440 whp to ZL1 was world of difference. Faster in every way. It pulls like a freight train all over the speeds and RPM. |
Probably doesn't like you
Drives: 2022 WCT ZL1 M6 Join Date: Jun 2015
2017 M6 SS 50th convertible (tuned, probably ~25RWHP gain) to 2022 M6 ZL1 coupe (stock).
The answer to your question is "it depends" for my case. Say 35-85... I can be in 4th gear at 35 in the ZL1. Then floor it, and it will go, faster than an SS, for sure, especially the deeper into the RPM you go and power builds. I can also be in 1st gear at 35MPH... well floor it, you better hope it's warm out or you're gonna spin. If you don't spin, and it grips, then yes, there is MUCH more thrust than a SS. 100% noticeable and will give you a sh*t eating grin. For an auto, in Performance shift, I'd imagine it'd be easily noticeable, too, since it'll want to keep you in the meaty section of the powerband. Driving a ZL1 'lightly' there is almost no perceptible difference between the cars. In fact, the ZL1 is more nose heavy, than a SSLE, but once again not sure anyone who hasn't tracked would notice it, I sure don't. Driven in anger, the ZL1 is bonkers. That's honestly the best word I could come up for it. My good buddy at work tunes his own cars, on E85, a 2019 GT 5.0 PP1, and during his first drive of my car all he could say was "Holy sh*t... so much power, everywhere..." My previous performance car was a '17 911 S with a PDK, so I am kind of familiar with 'fast' things. So in short, yeah, it's a step change in power, that is 100% as noticeable as you want it to be.
كافر ΜΟΛΩΝ ΛΑΒΕ железобетонное очко Quod gratis asseritur, gratis negatur. There is an unequal amount of good and bad in most things, the trick is to work out the ratio and act accordingly. |
#4 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2023 Summit White Camaro ZL1 M6 Join Date: Dec 2021
The ZL1 is basically a SS 1LE on steroids, with slightly more weight on the nose. Driven normally it basically drives like an SS 1LE. However, when you get on it, even for a few seconds, the acceleration is bonkers and the speed increases noticeable faster than in a 1LE. And traction on throttle is definitely more of an issue in the ZL1.
2023 Dodge Durango SRT (daily driver) 2003 Nissan 350Z (modified) 2022 Rapid Blue 1SS 1LE M6 (delivered 2/19/22) (Sold) 2009 BMW 135i (Sold) |
Thanks all. Sounds like the Zl1/650+ HP car will push me through the seat based on your descriptions which is exactly what I want haha.
#6 | |
It's hard to express the physical sensation using numbers, but check out my approximate torque by rpm table, you'll see that the ZL1 has 50% more torque roughly up to 4000 rpm, and even after that retains a 40%-ish lead throughout the rev range. Code:
SS ZL1 2000 365 550 2500 400 600 3000 420 625 3500 435 650 4000 450 650 4500 455 635 5000 450 625 5500 425 600 6000 400 585 Now if you take it a few notches further, that's when words like "bonkers" come to mind My car is already scary frikken fast with a good amount of extra power over a ZL1 (at less weight, too), but the real deal is those 850-900 rwhp beefed up ZL1s, once you ride in or drive one of those, it's a jaw dropping experience, the only words I can think of is absolutely brutal and visceral.
#7 |
![]() ![]() ![]() ![]() ![]() Drives: 2020 Chevy Camaro ZL1 Join Date: Apr 2023
95% of the time, my car stock has enough power for me. I think a 100 shot of nitrous for the other 5% is probably all I would need.
#8 |
![]() Drives: 2022 Camaro zl1 Join Date: Jun 2023
Very noticeable difference. I went from a 23 2SS to a 22 ZL1 both 10speed auto. As others have said just putting around they feel about the same. The ZL1's suspension is a bit tighter and the braking is much better, it was the first thing I noticed when I drove it. When you get past 30% throttle you really notice it. The power the PD blower makes is all across the RPM range and very, very noticeable.
#9 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2024 CT5-V Blackwing Join Date: Sep 2020
The ZL1 is going to accelerate quicker at any speed because of the additional HP and Torque. You could make the argument that from 0-60 the difference might be less noticeable only because the ZL1 will be more traction limited.
#10 |
Oh yeah, the difference is immediately noticeable. I was considering upgrading my 2017 2SS A8, but decided to trade up to a 2019 ZL1. Glad I did!
#11 |
Sarcasm loading --------
Everything about the ZL1 is better.
If you drive one you will notice it immediately.
2018 MBM ZL1 1LE - 652 rwhp, 588 rwtq SAE 2014 CRT ZL1 574 rwhp, 537 rwtq - SOLD 2010 IBM SS Camaro VVT L99 w/ TR6060 swap, 489 rwhp, 444 rwtq - SOLD |
#12 |
![]() Drives: 2022 ZL1 Join Date: Dec 2021
Night and Day difference
Apples to Oranges |
#13 |
Echoing everyone elses sentiment.
Just went from an A10 SS1LE to a ZL1. I loved my SS1LE but even when I used half throttle in the ZL1 for the first time I knew the car was going to be a riot. First pull I did in the ZL1 made me grin ear to ear. You will get pushed back into your seat for sure. |
#14 |
![]() Drives: 2017 ZL1 A10 Join Date: Sep 2013
Pretty much what every one else is saying it is a night and day difference. I went from a 2010 SS auto to a 2017 ZL1 and the cars are not even in the same league! Now, between the two I had a 1972 Chevelle SS with a 467 big block that was around 650 horsepower and 650 ft./lbs. and that car was just raw power naturally aspirated. Weighed less than the Camaro, but the Camaro is faster in a different way. The Chevelle was a handful if you did not know what you are doing in the same way as the Camaro, but the Camaro has better brakes, better traction, better acceleration higher in the RPM range... Just better and more refined but the two cars are completely different!
'17 ZL1 Hyper Blue
A10, PDR, Exposed Carbon Fiber Hood Insert |
