Old 05-04-2024, 10:19 PM   #1
JSH
JSH's Avatar
Drives: '20 ZLE
Small lightweight Jack?
I'm looking for a small lightweight jack to be used solely for changing rear tires in my garage and at the track. I tried a 12v jack from Amazon today but it was 1/4" too tall to reach my lift plates.
I've got the usual 2-ton floor jack that weighs a million pounds, and is a bitch to move around. I'm looking for the smallest jack. Suggestions?
2020 ZL1LE A10.
100 octane: 1045hp/1055tq.
Old 05-04-2024, 11:26 PM   #2
Dirtbike
Drives: Chevrolet Camaro
https://www.amazon.com/BIG-RED-TAM81...4&sr=1-26&th=1
This is what I carry in the trunk when going to the track.
Dirtbike is offline   Reply With Quote
Old 05-05-2024, 07:46 AM   #3
Vivid24
Vivid24's Avatar
Drives: 2024 Camaro ZL1
^^^These work great.
Vivid24 is offline   Reply With Quote
Old 05-05-2024, 09:48 AM   #4
Dynamical
Dynamical's Avatar
Drives: 2022 Camaro LT1 A10
Specifically for the track I got this. I use it one wheel at a time and use a home made lift puck. The jack is 33lbs aluminum.
https://www.harborfreight.com/automo...ump-64545.html
2022 Camaro LT1 A10 - Drag Pack/Corsa double X pipe/AWE track axleback -11.849@118.67MPH/1.798 60'
Dynamical is offline   Reply With Quote
Old 05-05-2024, 11:16 AM   #5
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
I've used a trolley jack similar to this one for 40 years. Small enough to fit in my trunk with the top down.
https://www.amazon.com/BIG-RED-TAM81...82MRT2M5/?th=1
Old 05-05-2024, 05:49 PM   #6
Spaceme1117
Spaceme1117's Avatar
Drives: 2017 Camaro SS, 2011 Corvette GS
https://www.calcarcover.com/product/...minum-jack/705
You would need a few 2x6's of a few layers of plywood stacked on top of each other to go with it to place underneath the jack to get it as close to the jack point before starting to lift. About as light and simple as you will find.
Spaceme1117 is offline   Reply With Quote
Old 05-05-2024, 07:06 PM   #7
Kamero6
Drives: 6th Gen LT1
I have the same and it compains when I lift the front of the car. The pump Orings failed and got the pistons stuck. Had to sand them to free up the pistons. Now its leaking.
I'm very careful with it and always use floor jacks.
I bought a cheap scissor 3 tons capacity for the trunk and it works better
Kamero6 is offline   Reply With Quote
Old 05-05-2024, 07:31 PM   #8
Curr
Probably doesn't like you
Curr's Avatar
Drives: 2022 WCT ZL1 M6
+1 to the Harbor Freight aluminum low profile.
كافر
ΜΟΛΩΝ ΛΑΒΕ
железобетонное очко
Quod gratis asseritur, gratis negatur.
There is an unequal amount of good and bad in most things, the trick is to work out the ratio and act accordingly.
Curr is offline   Reply With Quote
Old 05-07-2024, 05:44 PM   #9
Dynamical
Dynamical's Avatar
Are you comparing a 3 ton vs 1.5? I have the exact one I posted which is the 1.5 and like I said I use it one wheel at a time. I would not use it to lift the whole front or back. It's just for the track and I had no issues. I have a 3 ton low profile for the heavy lifting. That weighs like 80lbs so there's no way I would haul that to the track
Old 05-09-2024, 08:49 AM   #10
JSH
JSH's Avatar
Drives: '20 ZLE
Yeah, I want the lightest say 1.5-2.0 ton jack to lift one rear wheel an inch off the ground. I found a 12v jack but it was 1/4" too tall. I have the std. 3 ton jack but it's too heavy and awkward to move around.
And, I use an 8T hitch, 3750# car, and 24 ft trailer, so I'm also trying to reduce the weight that I put in the trailer and on the hitch.
The lightest jack suggested here so far is 30+ lbs. which would be a big improvement.
2020 ZL1LE A10.
