Old 05-03-2024, 06:03 AM   #1
2023_ZL1-AUTO
2023_ZL1-AUTO's Avatar
Drives: 2023 ZL1
trailering your ZL1...
So, I'll be trailering my ZL1 to Katech for additional work, approx. 230 miles. The only trailer I have access to is an open trailer. Would it be wise or not to get some kind of heavy duty car cover for trip or would that just be a hassle and would the speed cause the cover to possibly damage the paint or anything? We're pulling it behind a GMC Sierra HD Denali Diesel. Thanks
Katech Track Day CAM 38%•BTR Dual Valve Springs•Johnson Lifters•Trend 3/8 Chromoly Pushrods• VVT Del•CNC Heads•AFM Delete• C5-R Timing Chain•Katech Oil Pump•Katech 112mm•Maggie 2650 3.25” Upper/ATI SD w/10.32” +20%•10 Rib Belt•RFBG•FI IC Stage 2•THPSI Port w/875cc Inj•Katech Dual Fuel Pump•DSX Aux Pump•SW 2" Headers w/Legend NPP•GESI UHO 4.5" CATs•Brisk RR14S Plugs•BMR Motor Mounts•BMR Cradle Lockout &Bushings Kit•BMR Rear Suspension & 15" Conversion•DSS 1pc DS•RPM 6-Point Roll Cage•10lb FireSense+ w/4Fire SFI 17.1 Fire Sys•Weld Forged Vitesse Rear 17x10 Beadlocks-Front 18x6•Unlocked TCM
Old 05-03-2024, 07:19 AM   #2
bootss
Drives: 2021 ZL1 1LE with PDR
Don't put a cover on it, the wind will eat it and cause it to eat your paint. I tow on an open trailer to the track, no issues. Make sure you have good mudflaps and you'll be fine.
I tow on a GMC 1500 with airbags and extended mudflaps. My only beef is the damn bug splatter.
bootss is offline   Reply With Quote
Old 05-03-2024, 07:27 AM   #3
Camfab
Drives: ‘23 ZL1-1LE
https://mbrmarketing.com/body-shop-s...transport-wrap
This is an option, I’ve also used a heavy duty wide stretch wrap you can buy at Home Depot as well.
Camfab is offline   Reply With Quote
Old 05-03-2024, 07:29 AM   #4
2023_ZL1-AUTO
Drives: 2023 ZL1
bootss & Camfab ! Thanks for the info!!!
