JP_chachasama
Drives: 23' 2SS Convertible Summit White Join Date: Aug 2023
Life is not easy (DIY oil change)
It's just the second oil change at 5000 miles. The first one the dealership implemented for free at 2000 miles.
I tried to remove the oil filter using an oil filter wrench, but it did not work. It was super over-torqued. It really frustrates me. ![]() Finally, using an adjustable plier, it figured out. Some dealership technicians have no brains.
23' 2SS Convertible Summit White MRC NPP PBBrakes
03' Mercedes CL600 I Love DIY |
#2 | |
2020 Shadow Gray 2SS
Expensive warranty work, fine, find a VERY reputable dealer... Basic maintenance (oil or diff changes), do NOT let them near your car, free or not... NOT worth it, 90%+ of the time something bad will happen, NOT worth the risk on these high performance, unique vehicles...
After delivery: - GMP CAI, GMP Black Strut Tower Brace, MRR017 1LE Wheels, SS Armrest, Black Fuel Door, Stainless Pedals, SS Wheel Caps, GM Splash Guards, DD Smoked LED Markers, Smoked Rear Reflectors, Mishimoto Catch Can, Xpel PPF-Full Front & Rockers, 35% Tint, CeramicPro coated, RST Stainless Brake Lines, Castrol SRF, MSD Plug Wires, Mamo V3 Ported TB Left: My "fun" ride (475 HP). Right: My "work" ride (52,000 HP): a Gulfstream G600. One's top speed is 180 Mph, the other, 620 Mph. BOTH AWESOME to operate... |
#3 | |
![]() Drives: 2019 Chevrolet Camaro 2SS A10 Join Date: Jul 2019
, I have done my own maintenance every since.
2019 Camaro 2SS A10 Procharged, Flexfuel, with Stainless Works headers back to Legend series mufflers.
Oh now that's funny, so he put the wider rears on the front???
Yes, I couldn’t believe it, haven’t been back to the dealer since, I think the lucky stars that I never even needed anything other than regular maintenance
![]() Drives: White 2024 1SS M6 Join Date: Nov 2023
It's funny you fellows mention the free oil change and tire rotation. I was getting ready to set up an appointment for my free oil change and they mentioned a free tire rotation as well, I reminded them it was a Camaro and they did catch themselves on not rotating the tires, but I wonder if I hadn't said anything if they would have rotated them or not.
#7 | |
![]() ![]() ![]() ![]() ![]() Drives: 2020 Chevy Camaro ZL1 Join Date: Apr 2023
#8 |
![]() Drives: 2019 ZL1 "1LE" | 16 SS | 2017 F30 Join Date: Dec 2021
Torque until it starts getting loose and then half a turn back.
Callaway SC750 ZL1, DIY 1LE with added OEM 1LE Wheels, DSSV Suspension and 1LE Aero, FEA front control arms, DIY oil cooler, CWA 150 pump, bigger intercooler, Phenolic blower spacer, 82°C thermostat, BMR lockout kit, CTSV Brake Air Deflectors, Smooth idle cam, LS7 lifters, Bronze trunnion bushings. Tuned by JRE
#9 |
JP_chachasama
OMG! Big tire to front? I can't believe... crazy. I don't want to go to any dealership for maintenance.
#10 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 1SS 6spd Join Date: Jan 2011
When it comes to ASSuming someone knows better, you can never let your guard down. I didn't trust the local Big Tire specialist's to remove or replace my wheels when I replaced my OE run-flats. I ordered a stock size set of Michelin PS4S's and took them in the wife's Subaru with my Camaro's wheels/tires to the tire shop for mounting and balancing.
When I got home and started to put them back on the car, I realized they had put the back tires (275mm) on the 8.5" front rims and the 245's on the 9.5" back wheels. Just cuz yur paranoid doesn't mean they all aren't out to get you!
#11 | |
![]() Drives: 6th Gen LT1 Join Date: Jun 2023
They need to compete with JiffyLube |
#12 |
![]() ![]() ![]() Drives: 24 LT1 M Join Date: Oct 2015
I had my first oil change done, they spilled oil around the engine and didn't clean it off. Smelled oil until it finally burned off. The interior also smelled like grease/oil. Low IQ people.
24 LT1 M6 Sharkskin Metallic
22 Mazda CX-30 |
