Old 04-29-2024, 04:01 PM   #1
NovaSS4spdFan
Drives: 2024 2SS vert w/M6 & Dual Mode. Red
6.2 V8 and issues with AFM(Active Fuel Management)
I have a friend who is an A level mechanic at a GMC dealer who sees a lot of warranty (and out of warranty) work coming thru the shop on 6.2 equipped Sierras and Yukons due to significant lifter problems caused by AFM(Active Fuel Management) also known as cylinder deactivation. He asked that I post this because his friend just shelled out $115 (K) large for a Cadillac Blackwing with the LT4 and 10 speed auto. Awesome car.
I don't know the extent of the problem with Camaro6, C7 and C8 Vettes that have auto trannys. Are there preventive measures one can take if they have a AFM vehicle before having to have it torn apart ? Will more frequent oil changes help?
I feel fortunate that my manual trans equipped Camaro6 hasn't got it- just Direct Injection. Not rubbing it in, mind you just curious and wishing luck to anyone with AFM. BTW, the Blackwing is available with a 6 speed.
NovaSS4spdFan is offline   Reply With Quote
Old 04-29-2024, 04:08 PM   #2
easttxss
easttxss's Avatar
Drives: '16 2SS M6
The issue is the lifters wear and will stick in the collapsed position. You have all the same components in your engine, it's just missing some wiring and the computer is not programmed to actuate it so the manual cars don't see the failures. The easy, pre-failure fix is to turn it off in the computer via HP Tuners, or get a Range device to deactivate it.
David
'16 2SS M6 black on black, SW long tube full exhaust, NPP, Roto-fab CAI, ported stock TB
'16 2SS M6 black w/Metallic black stripes, Kalahari, 6 piston front (totaled 1/22/20)
'14 Fusion Titanium 2.0T
'83 Jeep Wagoneer
easttxss is offline   Reply With Quote
Old 04-29-2024, 04:25 PM   #3
jericho_17
Drives: 2017 Camaro 1LT
or you can disable it via Trifecta tune
jericho_17 is offline   Reply With Quote
Old 04-29-2024, 04:53 PM   #4
MT-SS1LE
Drives: 2023 SS 1LE Sharkskin
I installed a Range device on my car at 1500 miles and it will never be removed unless absolutely necessary for warranty work. The fuel savings are minimal and certainly not worth the risk of lifter failure, imho.
ΜΟΛΩΝ ΛΑΒΕ
MT-SS1LE is offline   Reply With Quote
Old 04-29-2024, 05:45 PM   #5
Dynamical
Dynamical's Avatar
Drives: 2022 Camaro LT1 A10
I have a range plugged in 24/7 and it will only come out after the car gets a real tune. Headers and boltons are in the very near future.
2022 Camaro LT1 A10 - Drag Pack/Corsa double X pipe/AWE track axleback -11.849@118.67MPH/1.798 60'
2001 Camaro SS A4 - HCI/Stall/Bolt-on/Gear/Tune/DR/Diet - 429HP/392TQ - 10.99@123.58MPH/1.584 60'
1998 Camaro Z28 A4 - Bolt-on
1999 Camaro Z28 A4 - Stock
Dynamical is offline   Reply With Quote
Old 04-29-2024, 05:48 PM   #6
olrocker
olrocker's Avatar
Drives: People crazy with my sexiness
4 easy steps to fix this:
Step 1: Remove factory cam and lifter junk with VCM
Step 2: Install new cam and lifter set sans VCM
Step 3: Throw factory cam and lifter set into trash
Step 4: Happy motoring
Purchase order submitted on 6/23/23
Received and purchased 9/8/2023
2024 2SS 6MT coupe
Sharkskin/Light gray
Moonroof/Navi/NPP/Mag Ride/Red Brake Calipers
Gray painted split spoke wheels
Illuminated footwells/illuminated bowtie
olrocker is offline   Reply With Quote
Old 04-29-2024, 06:56 PM   #7
Junction65
Junction65's Avatar
Drives: 2011 GMC Sierra 1500
You may want to research this a little more in order to understand how the manual cars are different.
Direct Injection (compared to Port Injection) is just the location of the fuel injectors. As someone else posted above, you have the same AFM parts (cam and lifters) as an automatic car however the AFM software is not enabled/installed so the deactivation does not occur with the manual.
2023 LT1 Coupe M6 - Black (GBA) on Black (H1T)
Blade spoiler (5ZU), Recaro seats (AQJ), Technology pack (Y3W)
LT1 PBC engine built by Shane Parker
Current mileage: 372
Junction65 is online now   Reply With Quote
Old 04-29-2024, 07:02 PM   #8
CalgaryZL1
CalgaryZL1's Avatar
Drives: 2020 Chevy Camaro ZL1
Unfortunately/fortunately?, the LT4’s have the junk but not the brains to make the junk work, so it’s only half junk if you know what I mean.
Old 04-29-2024, 07:32 PM   #9
RIPws6
RIPws6's Avatar
Drives: 2019 2SS Riverside Blue
This should be pinned. Although many are aware of the issue, some are not.
RIPws6 is offline   Reply With Quote
Old 04-29-2024, 07:44 PM   #10
CHASLT1
Drives: 2021 Camaro LT1
The C7's had huge probs with the A8 on the 2015's and up. I had to lemon law a new 2019 C7 with 450 miles with shudder and a bad rear end friends.
I have had a used 2015 C7 Z51 for about a year with a A8 that was never touched or had the triple flush and it works like a dream. Only thing it has done is the hard shift out of park in super hot weather last summer . Not done it in many months and when the mid 90's come back i will see if it does it again.
Just beats me why so many A8's were bad and a few never had a prob. Had three C6's and never a prob with the A6.
CHASLT1 is offline   Reply With Quote
Old 04-29-2024, 08:16 PM   #11
knighti2
knighti2's Avatar
Drives: 2SS M6 Hot Wheels #515
Yes it is an awesome car and I love it. I have a 22 M6.
The same junk, AFM blah blah blah, is in the 5.3L that is in the Silverado I now have. Followed olrocker's 1-4 directions to the T.
So at 150K, when it was given to me by my Dad, figured was good time to overhaul the engine and get rid of that junk. Hopefully she goes another 2-300K
Rotofab, Soler 87mm ported TB, Kooks headers / green cats, MSD wires, flex fuel
Stock intake (no porting) and stock NPP exhaust.
knighti2 is offline   Reply With Quote
Old 04-29-2024, 10:25 PM   #12
The basic underlying problem is that the older fluid variants in the A8 are more susceptible to absorbing moisture and gradually surrender their friction properties, which leads to rapid slip-grab and the breakdown of the friction material on the torque converter clutch. I've seen a few graphs depicting the fluid deterioration problem with old fluids and how the 2019 fluid finally resolved the issue.
From that information my conjecture is the issue impacts cars used in areas with higher humidity much more severely than drier regions, which would explain why only a smaller but relevant subset of A8 units degrade to the point where the shudder becomes tangible.
Old 04-30-2024, 12:56 AM   #13
Bumbleboy92
Long hauler
Bumbleboy92's Avatar
Drives: 2022 Camaro 2SS 1LE
Here’s a look at post failure, think it was best case failure scenario imo
I didn’t own the car when it happened so it’s all I got
2016 1LT v6
- Totaled
Happiness: Infinite
Old 04-30-2024, 01:36 AM   #14
NovaSS4spdFan
That's unfortunate- just 10K miles and a lifter issue.
