Old 04-27-2024, 06:25 PM   #1
MatthewAMEL
MatthewAMEL's Avatar
Compensate for altitude?
Moving from sea level to Denver.
Contemplating a pulley switch (from OEM 2.5" to 2.3") to attempt to recoup some of the lost power.
Any other ideas I should be looking at? I don't want to tune.
Thanks.
2017 HBM SS 1LE
Sold
2023 Wave Metallic
CT5-V Blackwing M6
2025 Hysteria Purple
C8 Z07
Old 05-10-2024, 03:49 PM   #2
JANNETTYRACING
JANNETTYRACING's Avatar
Thanks.
We always recommend an ATI superdamper with overdrive lower rather than changing the upper and loosing belt traction.
We carry ATI if that helps.
www.jannettyracing.com
email tedj@jannettyracing.com
Old 05-10-2024, 04:19 PM   #3
dreksnot
Served USN - Atomic Chimp
dreksnot's Avatar
Drives: 2021 Camaro ZL1 1LE A10 (stock)
The correction factor in Denver is about 1.20 - yes, that's a heap of HP loss sucking this thin air up here.
Most ideas to make up for that lost 115whp are: headers, throttle body, E85, S/C porting. And, most of those require a tune to get fueling right (if you already have fueling available).
> Past Builds: 2013 Twin-Turbo LSX434 M6 - 1,359rwhp daily
dreksnot is offline   Reply With Quote
Old 05-10-2024, 08:50 PM   #4
MatthewAMEL
Thanks for the reply. It's actually for the Blackwing. I can do everything on your list except the E85 without a tune. The Blackwing has OEM Wideband O2 sensors and a much faster ECU.
Is E85 avail in the Denver area? I'm down south in Parker.
2017 HBM SS 1LE
Sold
2023 Wave Metallic
CT5-V Blackwing M6
C8 Z07
Old 05-10-2024, 10:04 PM   #5
dreksnot
dreksnot's Avatar
Yes, I've heard folks say the get some and some places are better than others. There's probably places around Parker and that neighborhood. Download the GasBuddy app and look for E85 on it (near you).
Old 05-11-2024, 08:24 AM   #6
JSH
JSH's Avatar
Drives: '20 ZLE
Thanks.
You're going to lose 130 bhp or more on a stock LT4. You can't recover that unless you make some of the mods discussed here daily. An E85 Flex Fuel kit and a tune are probably the least expensive ways to regain power. You can spin your blower faster too but additional heat will be a problem.
2020 ZL1LE A10.
100 octane: 1045hp/1055tq.
