Old 04-26-2024, 01:17 PM   #1
pauly1119
pauly1119's Avatar
Drives: 2018 ZLE
Katech Oil pump
So after thinking everyone was crazy for swapping their pumps that had no issues, that’s exactly what I did. Bought the Katech pump, timing chain and the LME damper and had them all installed at my local dealer which has a very good known Corvette mechanic. I have a late model 2018 build the last few days of 6/18, I had zero issues but plan on keeping this car for a long time. It’s a 2018 ZLE. Original oil pressure never dropped below 28 psi and seamed fine, with the Katech pump I’m seeing much higher pressures. Cold idle is above 40 psi and hot is around 35. The biggest difference I’m seeing is on throttle, 2000 rpm normal driving is 50psi and 3000 rpm is hitting 60psi. It floats between 50 and 60 now with normal driving. I was never close to those pressures before. Another thing I didn’t know was my belt tensioner was leaking I guess they are hydraulic but that was changed under warranty which expires in Aug. I’m glad I did the upgrade, I’ll never know if it would have failed or if it would have been fine but now I’m pretty sure I’m good. I also saved the old parts and they still all look new. The pump removed had a part # stamped on it 7142.
pauly1119 is offline   Reply With Quote
Old 04-26-2024, 01:24 PM   #2
Z OH 6
Drives: 2024 CT5-V Blackwing
Good stuff! If you don't mind me asking, how much did the dealer charge you for labor?
Old 04-26-2024, 01:31 PM   #3
pauly1119
pauly1119's Avatar
Drives: 2018 ZLE
It wasn’t cheap at least compared to the prices I was seeing on the forums. I supplied all the parts but the mechanic wanted all new bolts and a few gaskets I missed. $3,700. The mechanic sent me videos and pictures during the process and said to stop by when ever I wanted to see it.
Took 1.5 weeks because of the few parts I didn’t supply.
Old 04-26-2024, 02:06 PM   #4
Z OH 6
I've always heard around $3k so not too far off.
Old 04-26-2024, 04:19 PM   #5
nighttowl
Sarcasm loading --------
nighttowl's Avatar
Drives: 2018 ZL1 1LE
Dealership here in Texas wanted $4500 to change an oil pump.
2018 MBM ZL1 1LE - 652 rwhp, 588 rwtq SAE
2014 CRT ZL1 574 rwhp, 537 rwtq - SOLD
2010 IBM SS Camaro VVT L99 w/ TR6060 swap, 489 rwhp, 444 rwtq - SOLD
nighttowl is offline   Reply With Quote
Old 04-26-2024, 04:57 PM   #6
pauly1119
pauly1119's Avatar
Drives: 2018 ZLE
I’d rather pay more knowing someone good is working on it. I’m very happy with my mechanic. I was quoted 6k from another private shop with me supplying parts. Since I did the chain and damper parts were over 900 for just those 3.
Old 04-27-2024, 08:34 AM   #7
jjgi5150
Drives: 2022 ZL1 1LE
Pauly1119,
Just curious as to your oil pressures now with the new pump. I am curious to see what the Katech pump runs at idle, cruising and under throttle. I would like to compare to my ‘22’s pressure readings, which compared to my ‘18’s are excellent.
Thanks
JJ
2018 ZL1 1LE, NGM, Nav, PDR, born 11/22/17 SOLD
2022 ZLE, MH3, WCT, Nav, PDR, born 10/21-5/22!!!
2021 F-250 FX4
2023 Hyundai SF Calligraphy
jjgi5150 is offline   Reply With Quote
Old 04-27-2024, 08:49 AM   #8
pauly1119
pauly1119's Avatar
Drives: 2018 ZLE
Originally Posted by jjgi5150 View Post
Pauly1119,
Thanks
JJ
At cold startup I’m seeing slightly above 40 psi, at full temp after driving it home I was slightly above 35 at idle. With my stock pump I would see 40 psi at startup and just at 30 or slightly below at full temp so not a huge difference. The big difference is under throttle. I drove it pretty easy on the way home as I’m not sure if there is any break in period but I was between 50 and 60 psi under throttle between 2 and 3k rpm’s. I would only see those pressures with the old pump when I really got on it. Even the mechanic said he is sold on these katech pumps, he was showing the other techs in the shop how much of a difference it has under throttle. The tech said he doesn’t see this response with the C7 Z06’s either. Hopefully it’s the way it’s supposed to be. I can take some pics or videos when I get a chance.
Old 04-27-2024, 02:19 PM   #9
jjgi5150
Pauly1119
Thanks very much for your response. I feel pretty lucky as my stock ‘22 oil pump is pretty much a clone to the numbers you gave. Who knows about material longevity in my stock pump, but the pressure so very much better than my ‘18 was. I never had an actual failure with the ‘18, but the low oil pressure worried me enough that I sold the car.
FWIW, my ‘22 also runs much better that the ‘18 did.
Good luck with your situation!
JJ
2021 F-250 FX4
Old 04-27-2024, 08:12 PM   #10
george
ZL1 Driver
george's Avatar
Drives: Camaro ZL1 & BMW M3/E92
@pauly1119, I totally sympathize with your situation. I'm right there with you. If the pump doesn't fail under warranty, I'm certainly taking it in. Obviously, I'm taking a chance that if the pump fails without warning, I'm out an engine. Luckily with only 1400 miles on it, I think it's still early. I will say that after an oil change the oil pressure went up to 40 at cold idle and settled down to 32 at warm idle, which is a bit higher. I did hit 55-60 cruising. I was glad to see it at 32 at warm idle though. That is reassuring for now... Please post videos and/or pictures, I think we are all interested who are in this situation.
george is offline   Reply With Quote
Old 04-27-2024, 08:35 PM   #11
george
ZL1 Driver
george's Avatar
Pauly1119
JJ
What was the pressure on your 18 at warm idle? What is it with your new one
Old 04-27-2024, 09:10 PM   #12
pauly1119
pauly1119's Avatar
Drives: 2018 ZLE
Yes Ill post some pictures but I don’t get home from work until Monday morning. My car only has 7k miles but my warranty is up in August and I was tired of thinking about it to be honest. Heck I paid the same amount for PPF protection and this is probably the best thing I can do for the engine. I was already stupid with excessive oil changes and sending my oil for analysis.
Old 04-29-2024, 02:12 PM   #13
pauly1119
pauly1119's Avatar
Drives: 2018 ZLE
I took it out today for a long cruise nice hot Florida afternoon. These are just light driving around pressures. The pressure would go slightly higher at first and then settle in under throttle. I stepped on it just once.
Old 05-04-2024, 03:32 AM   #14
george
ZL1 Driver
george's Avatar
Thank you for the pictures. It’s got to be a relief to be free from the constant stress. You want to take it to it’s limit without worrying.
