Old 04-25-2024, 10:32 AM   #1
flobb
Drives: 2022 2SS
Did full car in Plasti Dip
Been thinking about it for a while and decided to try doing my whole car spray wrapped in Plasti Dip. This is my first time doing a full car. It went decently well but there are definitely some screw ups and lessons learned.
Color: Zombie Midnight Flip 15 grams per gallon in Frozen Clear topcoat over a black base. Hood and roof left black (and need some fixing).
flobb is offline   Reply With Quote
Old 04-25-2024, 10:51 AM   #2
N Camarolina
N Camarolina's Avatar
Drives: 2021 2SS 1LE
That's an interesting approach I wasn't aware of, and looks nice from a distance (I didn't see the errors you mentioned). Thanks for posting.
Is this the equivalent of getting your car vinyl wrapped? Can you peel it off completely at some point without any damage to OEM paint beneath?
N Camarolina is offline   Reply With Quote
Old 04-25-2024, 11:33 AM   #3
bandier
Got mine!
bandier's Avatar
Drives: 2021 LT1 RS - Orange Crush
Looks pretty damn good to me! Niiiice!
Camaro lover since 1984 when I got my first car a 1978 Camaro LT with a 2 barrel carb on 305 V8... yes I put in a 350 with a 4 barrel.
bandier is offline   Reply With Quote
Old 04-25-2024, 11:36 AM   #4
flobb
Drives: 2022 2SS
That's the idea. As long as you do enough coats it should peel off nicely. Otherwise it can be a pain in the butt to remove. Like, my car was black to begin with but I still did 4+ coats of black base, then 2-3 of the pearl topcoat.
Old 04-25-2024, 12:06 PM   #5
22SS1LE
Drives: 2022 1SS 1LE 6M
If you have any thin spots when trying to remove just use a tar remover like Stoners tarminator and it will melt it off
2022 1SS 1LE 6M in Riverside blue
Found exact build local- ETA 7/31/22
New ETA - 7/26, 7/30, 7/31, 8/1, 8/8, 8/15, 8/21, 8/28, 9/17
8/24. IT HAS ARRIVED at the dealer
8/25- It is in the Garage
ACS ZL1 Sideskirts, 20% tint, CAI Intake
22SS1LE is offline   Reply With Quote
Old 04-25-2024, 12:13 PM   #6
SSEssence
Instagram: Sangstah
Drives: 2019 Camaro 1LE
Came out pretty awesome! What's the longevity of a dip coat?
SSEssence is offline   Reply With Quote
Old 04-25-2024, 12:28 PM   #7
KC64
Gray Ghost
KC64's Avatar
Drives: 24 Camaro 2SS Loaded
You sprayed that Camaro all those times? Having it black already was a big help I bet! Pictures look good, hope it does not mess with the paint! Good Luck, it does look sharp!
KC64 is offline   Reply With Quote
Old 04-25-2024, 01:11 PM   #8
DaveC113
DaveC113's Avatar
Drives: 2018 Camaro 1SS 1LE
Looks good!
I did my wheels and am happy with how it came out but the coating isn't very durable.
Also, they have a "dip dissolver" product and often a pressure washer will take it right off.
Old 04-25-2024, 01:20 PM   #9
GreenZLE
Drives: 2020 Rally Green ZL1-1LE
Wow! I'm surprised at how good it looks! What was the cost?
GreenZLE is offline   Reply With Quote
Old 04-25-2024, 01:23 PM   #10
2SS Capt
2020 Shadow Gray 2SS
2SS Capt's Avatar
Wow, that actually looks really good!
Old 04-25-2024, 01:36 PM   #11
beowulf556
Drives: Camaro SS 1LE M6
How do you clean and care for it?
2018 Camaro SS 1LE M6
Stainless Works Headers & X pipe | Redline Axleback | E85 | Rotofab | Soler Ported TB | LT2 Manifold
beowulf556 is offline   Reply With Quote
Old 04-25-2024, 01:44 PM   #12
flobb
Drives: 2022 2SS
Actual product was under $400
  • 2x gallon frozen clear topcoat $140
    2x gallon uv concentrate black $140
    2x gallon VM&P thinner (to thin the black) $40
    30 grams pearl $40
I used a Wagner turbine sprayer that I also bought for other home painting projects. If I do it again I'll buy a different sprayer.
Then masking tape and other junk was probably another $30 or so. I did my pre-wash with regular car wash, then Dawn, then a spary bottle with diluted rubbing alcohol.
I have a couple of pretty bad runs due to a combination of poor lighting and my sprayer shooting uneven, plus my inexperience. I also didn't remove the spoiler so it's rough and thin underneath. I have a screw up on the hood because the black wasn't fully dry when I masked it off to do the pearl coat. I was rushing to get it done in my garage over a weekend.
Before this I've done some wheels and trim pieces. Those have held up fine for a few years with no maintenance.
Old 04-25-2024, 01:49 PM   #13
flobb
Drives: 2022 2SS
I spot tested Meguairs hybrid ceramic spray wax and it seems to work good. So I will go back and apply that to the whole car. Other than that, just regular hand washing. Bird doo doo and other things might be problematic but my car is garage kept when not driven so hopefully I notice and wipe it off early.
Like any self-marketed, influencer based business, they sell their own line of care and washing products. But I searched through the plastidip subreddit and consensus was that spray waxes like Turtlewax Ice are just as good or better without paying the premium.
Old 06-17-2025, 08:09 PM   #14
flobb
Drives: 2022 2SS
Freshly washed and treated with Meguiar's Hybrid Ceramic wax. This pic shows the color shifting properties better than the earlier ones. There are angles of the metallic green, blues, grays, and black.
More than a year later and no major issues to speak of. I peeled the roof and hood and it came off cleanly.
I do see some potential peeling on the underside of the front splitter, but only if I get down at ground level to look up at it.
