Old 04-24-2024, 07:49 PM   #1
george
ZL1 Driver
george's Avatar
Drives: Camaro ZL1 & BMW M3/E92
Oil pressure after oil vhange
Did anyone else notice that the oil pressure is a bit higher after a fresh oil change?
Here’s mine
george is offline   Reply With Quote
Old 04-24-2024, 09:08 PM   #2
Camfab
Drives: ‘23 ZL1-1LE
What was the oil temperature, was it the same in both instances? It’s also possible that the oil was diluted/contaminated with fuel.
Camfab is offline   Reply With Quote
Old 04-24-2024, 11:50 PM   #3
Kamero6
Drives: 6th Gen LT1
yes a couple of PSI. It's normal
Kamero6 is offline   Reply With Quote
Old 04-25-2024, 04:51 PM   #4
pauly1119
pauly1119's Avatar
Drives: 2018 ZLE
Mine after oil change.
pauly1119 is offline   Reply With Quote
Old 04-25-2024, 05:02 PM   #5
Z OH 6
Drives: 2024 CT5-V Blackwing
Colder oil will always be higher so it also depends on ambient temps.
Old 04-26-2024, 01:21 AM   #6
george
ZL1 Driver
george's Avatar
Yes, it was about 40psi with initial start. As it warmed up, the idle psi went from 40 to 31 when fully warmed up.
