Old 04-21-2024, 02:36 PM   #1
ghostlt1
Drives: 2021 LT1 convertible
A10 vs 6M gear ratios
I have a 2021 LT1 V8 with an A10 trans and was looking up more specs about the car. I noticed the gear ratio for the A10 is 2.77 and 3.73 for the 6M. Why is there a difference in gear ratios between the auto and manual transmission?
ghostlt1 is offline   Reply With Quote
Old 04-21-2024, 02:57 PM   #2
Deacon Blues
Drives: 2024 Camaro 1SS M6
I would think it is because there are more gears to climb in the A10.
Deacon Blues is offline   Reply With Quote
Old 04-21-2024, 03:20 PM   #3
Kamero6
Drives: 6th Gen LT1
I did that chart some time ago.
Kamero6 is offline   Reply With Quote
Old 04-21-2024, 03:51 PM   #4
ghostlt1
So the 2.77 gear ratio from the factory is the optimal setting for the A10?
Old 04-22-2024, 08:28 PM   #5
Kamero6
Drives: 6th Gen LT1
Almost, just think the engineers spent years thinking about this and with todays tech, It's getting hard to make anything better. Either because is already maximized, or its locked by complex software so anything you do will decrease overall performance.
The main difference is dictated by how manual and autos work internally, design and etc...
The A10 has planetary gears that are concentric and has 6 clutches, which engages 2 or 3 at the same time to produce this 10 different gear ratios.
The manual transmission has the limitation of the H pattern you need to manually shift and it reduces or multiplies speed by transfering movement from primary to secondary shaft back to output shaft.
Reducing speed too much with a high ratio, like 4.7 to 1 of the A10, means that one gear will be too big and the other too small. Small gears can't take much torque, and making everything larger will render the transmission too big and heavy.
So the different ratios 2.77 and 3.73 are based on design constrains and physics that have more to do with transmission design than anything else.
Rule of thumb and history tells us that that to launch a car you need a 10:1 final 1st gear in approx and reach Vmax in a 1:1 ratio @ rpm of max power.
The A10 does this, and the M6 too with Vmax in 5th gear @ 0.74:1, not ideal but having less power losses than the auto makes for it.
A10: 7th @6000 rpm = 181mph
M6: 5th @6000 rpm = 179mph
Sorry if the answer is overkill, but It is an interesting topic.
