Old 04-18-2024, 03:41 PM   #1
Crawco
Crawco's Avatar
Drives: 2021 Camaro ZL-1
oil is light brown smells like E85
I am changing oil again at 3000 miles but it look light brown and smells like E85
2021 Camaro ZL1
2019 Cadillac CTS-V
2018 Challenger Hellcat Widebody
2007 GT500 Super Snake
2008 Mustang GT Track Car
Crawco is offline   Reply With Quote
Old 04-18-2024, 03:48 PM   #2
CalgaryZL1
CalgaryZL1's Avatar
Drives: 2020 Chevy Camaro ZL1
If you drive the car spirited, no matter what fuel you’re running, 3000 is a good number. Oil is cheap.
Old 04-18-2024, 04:06 PM   #3
Megahurtz
Snackbar Tuning
Megahurtz's Avatar
Drives: 2023 SGM ZL1
Send it to Blackstone Labs and get a report
GM Gen V Calibrator
Old 04-18-2024, 04:23 PM   #4
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Normal for oil to smell like E85 after 3000 miles. That's where I would change it. The oil gets diluted faster because Ethanol requires a lot more volume to burn at the same lambda as pump gas. 20-30% more depending on how much ethanol.
Old 04-18-2024, 07:09 PM   #5
Z OH 6
Drives: 2024 CT5-V Blackwing
100% agree with everything said here. The color is normal and the oil should be changed at 3k using E85.
Old 04-19-2024, 06:15 AM   #6
2023_ZL1-AUTO
2023_ZL1-AUTO's Avatar
Drives: 2023 ZL1
Thanks O.P for mentioning this! This is GREAT info to know! I change my oil regularly as it is! But, I would have freaked out if it would have looked and smelled differently than I was expecting when I change it next. I changed mine at 500 miles and I'm still way short of 3000 miles for my next change. So I'll prepare myself not to panic!
Katech Track Day CAM 38%•BTR Dual Valve Springs•Johnson Lifters•Trend 3/8 Chromoly Pushrods• VVT Del•CNC Heads•AFM Delete• C5-R Timing Chain•Katech Oil Pump•Katech 112mm•Maggie 2650 3.25” Upper/ATI SD w/10.32” +20%•10 Rib Belt•RFBG•FI IC Stage 2•THPSI Port w/875cc Inj•Katech Dual Fuel Pump•DSX Aux Pump•SW 2" Headers w/Legend NPP•GESI UHO 4.5" CATs•Brisk RR14S Plugs•BMR Motor Mounts•BMR Cradle Lockout &Bushings Kit•BMR Rear Suspension & 15" Conversion•DSS 1pc DS•RPM 6-Point Roll Cage•10lb FireSense+ w/4Fire SFI 17.1 Fire Sys•Weld Forged Vitesse Rear 17x10 Beadlocks-Front 18x6•Unlocked TCM
Old 04-19-2024, 02:34 PM   #7
Evansa22
Evansa22's Avatar
Drives: 2018 HBM ZLE
Moto IQ has a good video of the effects of e85 on motors. They use a subaru but I'd imagine the principles are the same. Moral of the story... short trips on ethanol will start leaving sludge, even after only 2k miles I think it was.
Old 04-19-2024, 06:54 PM   #8
CalgaryZL1
CalgaryZL1's Avatar
Anything with short trips will leave sludge, and as we love our cars and baby them it’s a no-brainer maintaining them with frequent oil changes. Out with the shit and piss.
