![]() Drives: 2019 Chevrolet Camaro SS Join Date: Apr 2021
Trying to track an oil leak
I have an oil leak coming from somewhere on the front of the engine, and it seems to be coming from up high rather than low, because it’s running down. It also seems to be coming from the driver side. Tuner and i have tried finding this leak. we got the life of ourselves can’t spot it. but it is leaking. A lot. I never thought a heavy leak would be so hard to find. We’re going to end up pulling the motor if we have to.
Any ideas of where it could be coming from? Didn’t leak until previous tuner made a pull and it blew oil everywhere from the pcv. But has since gotten worse even with a catch can
'19 Camaro SS | LT4 High Side and LT4 injectors | Fore Innovations Triple 525 In-tank pumps | Too High PSI Secondary Port injection | E85 | Holley Low Ram | BTR Stage 3 S/C Cam | Circle D 3600 Stall | Forged pistons and rods | D1X procharger, 3.5 pulley making 18-20 PSI
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 23 ZL1 A10 Rapid Blue Join Date: Aug 2020
Check the oil pan bolts...a number of us had found leaks that originated there. My 1LE had three bolts adjacent to the filter that took a full turn to make them snug. My leak stopped entirely.
and just to make sure, your leak appear to be coming from the top as well? cause i mean the whole front of my motor is coated. what’s it doing? squirting up from the front of the oil pan or something? genuine question not arguing with you
I was just brainstorming a known leak point, you def could have a different problem.
i gotcha. i’ll definitely give it a good check just to check that box. thank you
![]() ![]() ![]() ![]() ![]() Drives: 2020 Chevy Camaro ZL1 Join Date: Apr 2023
Oil cooler line that leaks under load at operating temperature, making it harder to spot?
#7 |
where’s the oil cooler line located at?
#8 |
![]() ![]() Drives: People crazy with my sexiness Join Date: Jun 2023
I don’t mean to sound condescending because mechanics will scoff at this question, I’m genuinely asking: just check to make sure you tuner used dye and a black light to try to find the leak right?
Purchase order submitted on 6/23/23
Received and purchased 9/8/2023 2024 2SS 6MT coupe Sharkskin/Light gray Moonroof/Navi/NPP/Mag Ride/Red Brake Calipers Gray painted split spoke wheels Illuminated footwells/illuminated bowtie |
#9 |
![]() ![]() Drives: 2018 Camaro SS 1LE Join Date: Jul 2018
Front main seal?
#10 | |
Obsessed
Drives: 2016 Hyper Blue 2SS RS Join Date: Jun 2011
I was gonna suggest the same
2016 Hyper Blue 2SS |
#11 |
definitely not haha. we don’t have stuff like that. but, i wouldn’t be opposed to trying it i’m just not sure how to use dye for that
#12 |
#13 | |
https://www.amazon.com/ACDelco-10-50...4142940&sr=8-5 Then drive the car for a couple days, cycling on and off, highway and city stop and go, for probably 50 miles or so. Then put it on the lift and inspect everything under the engine with this: https://www.harborfreight.com/uv-lea...hoCyB4QAvD_BwE You’ll find exactly where your leak is in minutes or less.
#14 | |
| Tags |
| mechanical, oil, oil leak, procharged |
