Old 04-15-2024, 07:20 PM   #1
Jonathan91
Drives: 2022 Camaro 1ss 1le
2022 a10 tuning worth it?
I have a 22” fbo stage 1 cam tuned by gpi. I was thinking about sending my trans module to hptuners to get unlocked and have it tuned. Is it worth the effort and money? How much faster will it be?
Jonathan91 is offline   Reply With Quote
Old 04-15-2024, 09:28 PM   #2
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Lot of posts discussing this. TCM tunes are generally worth a reduction of 2 to 3 tenths of a second in the quarter mile.
Old 04-16-2024, 05:33 AM   #3
Megahurtz
Snackbar Tuning
Megahurtz's Avatar
Drives: 2023 SGM ZL1
Yes
GM Gen V Calibrator
Old 04-20-2024, 09:34 AM   #4
BMLMZ
Drives: 2022 Camaro ZL1
Very much yes. There is tq management in the TCM you cant turn off/down if you dont unlock it and tune it. You will be capped at a certain level otherwise.
BMLMZ is offline   Reply With Quote
Old 04-21-2024, 12:00 AM   #5
Jonathan91
Got it. I already know what ima be doing this weekend. My tcm should be the t93 right ?
Old 04-21-2024, 06:21 AM   #6
6spdhyperblue
Drives: 2SS 1LE
Livernois is able to unlock the t93 with their tuner. Wonder if hpt will be able to do that soon
Old 04-21-2024, 09:00 AM   #7
Joshinator99
Moderator
HP Tuners announced T93 support a while ago:
https://www.hptuners.com/product/gm-t93-tcm-services/
Old 04-21-2024, 05:46 PM   #8
6spdhyperblue
Drives: 2SS 1LE
The Livernois tuner is unlocking it through the OBD port. No needing to take it out and mail it.
Old 04-21-2024, 06:24 PM   #9
Joshinator99
Moderator
Much better off with HPT then any of the solid LTx tuners can work their magic. No way I’d want to be locked into one shop.
Old 04-21-2024, 06:42 PM   #10
6spdhyperblue
Drives: 2SS 1LE
I agree. I already have the ecm unlocked with hpt and the tune is finished. I’m not going to their tuner. I’m just wondering if hpt will go this route eventually since it’s proven possible. The tcm tuning is really the last part. I’d rather not fiddle with taking it out and mailing it if I don’t have to.
Old 04-24-2024, 08:29 AM   #11
JANNETTYRACING
JANNETTYRACING's Avatar
This is a subject not as cut and dry as it seems on the surface so take what the groups are telling you with a grain of salt
FBO, LOL! this is a good one that has no meaning because it means something different to everyone on the planet.
Not picking on you, Humans tend to follow trends even when they are bad ones.
I can unlock TCMs in house, no need to send to HPtuners any more, Your tuner should have the equipment by now.
The ECM calibration is a crucial to how the trans works.
These are torque based systems, so if the ECM CALIBRATION is off even the slightest, the TCM will not know what to do with the wrong torque reported by the ECM.
Stock A-10 Calibration is Spot on when torque reporting is correct.
So any gains from trans tuning on a modified car are typically to cover up poor torque reporting, otherwise little to no gains are to be had.
Also note you there is no drop in tune that will automatically make your car faster it would be a work in progress and you could potentially go backwards, again depending on ECM Calibration accuracy.
Changing Shift points to work better with a larger cam to take advantage of higher RPM Power curve capability are a benefit mostly in a drag racing venue.
This subject is a very deep one that most people will not understand so take what I am telling you very seriously.
Whether you can gain ET from Transmission tuning is all dependent on ECM CALIBRATION and modification list.
www.jannettyracing.com
email tedj@jannettyracing.com
Old 04-24-2024, 09:04 AM   #12
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Once you mod the car, the throttle will NOT open all the way at the hit of the throttle in the first couple gears. You will exceed the commanded torque by gear limit in the TCM. It gets worse as you do more mods.
Even a bone stock car will not open the throttle all the way on the launch until it rolls out. You will see a delay where the throttle is only 56-70% open for a second or two before the throttle actually opens all the way. This is a limitation in the TCM.
Most of the gains being mentioned are from the ability to launch harder. From a roll you might not see any gains depending on the setup.
This has been proven at the track with video.
Old 04-25-2024, 06:58 AM   #13
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
I had a BIG TM hit on the 2-3 shift if I recall before tuning it out. Heck - I'm positive I can hear it on newer cars, like the Escalade V (I don't think I've seen videos with the CT5-V doing a 2-3 shift, but I'd be it was there, too). It sounds like it falls on it's face for a moment right after the shift.
You are getting around that with MIN SPARK ADVANCE...
'20 ZL1 Black "Fury"
Old 04-25-2024, 07:11 AM   #14
JANNETTYRACING
There is absolutely no reason to mess with Min Spark Advance, it's there for a reason.
I see so many TOONS with that all jacked up.
Ted.
