04-14-2024, 03:46 PM | #1 |
Drives: camaro ss Join Date: Nov 2023
Higher oil pressure after oil change and fans on high?
Changed my Engine and procharger oil today once i started it up i realized the gauge for oil pressure is showing a lot higher than normal at idle and the fans are kicking on at high speed. Kind of at a dead end don’t know what i could’ve done when it was just an oil change…
04-14-2024, 03:48 PM | #2 |
Here is what the oil pressure is at when idle
04-14-2024, 04:00 PM | #3 |
Drives: 2004 BMW 330CI, 2022 1SS 1LE Join Date: Dec 2021
Looks normal to me, once the car warms up it will come down a bit.
04-14-2024, 04:01 PM | #4 |
Really? Before hand it would sit under 40 and would only go up that high on wide open throttle. And the fans are also kicking on full speed…
04-14-2024, 04:05 PM | #5 |
Mine has always read high when cold.
04-14-2024, 04:08 PM | #6 |
hmmm what would explain the fans kicking on then?
04-14-2024, 05:01 PM | #7 |
just drove the car home from work and this is where it’s at now still alot higher than before. It used to sit around 30-35
04-14-2024, 05:44 PM | #8 | |
2020 Shadow Gray 2SS
After delivery: - GMP CAI, GMP Black Strut Tower Brace, MRR017 1LE Wheels, SS Armrest, Black Fuel Door, Stainless Pedals, SS Wheel Caps, Black Lugs/Locks, GM Splash Guards, DD Smoked LED Markers, Smoked Rear Reflectors, Mishimoto Catch Can, Xpel PPF - Full Front, SunTek 35% Tint, CeramicPro coating, RST Stainless Brake Lines, Castrol SRF, MSD Super Conductor Wires Left: My "fun" ride. Right: My "work" ride: a Gulfstream G600. One's top speed is 180 Mph, the other, 620 Mph... BOTH are a lot of fun to operate... |
04-15-2024, 09:19 AM | #9 |
Drives: 2023 Camaro 1SS 1LE 6MT Join Date: Nov 2023
That oil pressure looks normal to me (Mine doesn't go below 40, usually). I do find after an oil change it does read a bit higher then before. As the oil ages you should see it go down slightly
04-15-2024, 09:51 AM | #10 |
Interesting problem.
The fans business I'm not sure about, but maybe rodents or heat got to wires? weird that the temp gauge seems to be working, yet fans on high. The oil pressure... Since you've done oil changes before (assuming same weight of oil), the pressure should not just jump 5 psi. Another weird problem, but I would maybe change the filter. Maybe the filter bypass is stuck open. |
04-15-2024, 10:31 AM | #11 |
Drives: 2023 Camaro 1SS Join Date: Apr 2014
Do the fans cycle on and off with the A/C turned on?
