Old 04-11-2024, 10:43 AM   #1
keep_hope_alive
Electrical Engineer
keep_hope_alive's Avatar
Drives: 2023 1SS A10 Black
Wind Noise Fixes - Mirrors and Pillars
After spending a lot of time making my '23 SS quiet (see link in sig), the wind noise from the A-pillar area needs to be fixed. I expect it is turbulence from the mirror housing and the edges at the triangular shaped area next to the mirror, in front of the window. Other threads have pointed to this area as well. I did search for this, and it's been a while since the conversation has been had and little resolution has been presented previously. Most of the threads ended with "GM said deal with it".
My window does index properly and does seal well. I will also experiment with window seal solutions, but treating turbulence noise at the source is also needed.
I'm going to start with experimenting with air diffusors and winglets and will report back when I find an adequate fix. If anyone has added parts to control wind noise, please share it here.
I'm starting with this kit: https://www.amazon.com/cueclue-Resis.../dp/B0BQHM8QYG
I can start taping over areas to help drive the areas of focus, and others have noted that taping will resolve noise, but that isn't a permanent fix.
Daily Driver mileage update: 45k mi. @ Mar 2025
Old 04-29-2024, 11:53 AM   #2
keep_hope_alive
Electrical Engineer
I've played around with this issue in the past weeks.
I ordered 3/8" silicone tubing to fill the gap in the weatherstipping. It fit well and looked good but it was too thick and didn't let the window into the pocket, so it just made the problem worse and was removed after the first test drive.
With the battery disconnected, the window logic will reset, so when you reconnect you will be prompted to cycle the windows. I've done this a few times and it's better but not perfect. I still think the window is 1/8" lower than it should be on the driver's side.
Adding the winglet kit is next.
Old 04-29-2024, 07:11 PM   #3
Kamero6
Drives: 6th Gen LT1
C4 corvettes used a rear view mirror deflector to help with this.
Kamero6 is offline   Reply With Quote
Old 05-02-2024, 03:42 PM   #4
keep_hope_alive
Electrical Engineer
I figured out what is happening, and I'll have a pretty easy fix for it. Simply put, a weather seal is folded in, which I will document with photos soon.
Old 05-03-2024, 03:27 PM   #5
keep_hope_alive
Electrical Engineer
This seal was folded over on itself, and that was causing the noise leak. You can see how creased it is.
I had to hold it back with enough pressure to let it correct itself as the window went back up. Now for some summer sun to soften the rubber so it regains it's original shape.
You can also see some of the added aero deflectors to quiet down wind noise at the side mirrors. I'll share some more pics of those, not totally sold on the aesthetics of the one on the mirror, as it's level with the ground not the angle of the mirror.
Old 05-04-2024, 02:34 AM   #6
roostere4
Drives: 1987 IROC, 2020 ZL1
Nice catch!
Hopefully a nice hot day will allow that seal to reset to position it should be in.
Any idea how it got folded over to begin with? Wonder if any need to on the lookout for to prevent this from happening
roostere4 is offline   Reply With Quote
Old 05-06-2024, 12:18 PM   #7
keep_hope_alive
Electrical Engineer
Originally Posted by roostere4 View Post
Nice catch!
They replaced the window motor while they had the car, and it came back that way, so it must have been during that process.
Old 05-10-2024, 11:38 AM   #8
keep_hope_alive
Electrical Engineer
I was able to find the source of the extra wind noise. There's a gap that allows air to get in to the door by the sale panel triangle. When my window seal was making noise I was wondering how air could even get there recognizing that had to be the source. So what I've done is temporarily put some rope caulk in there to seal it up and test. And I can say that driving on the interstate that source of wind noise is gone.
I do have a couple winglets still on that triangular panel on the outside to try and break up some of the air. It's hard to say if those winglets are doing anything at this point. So I may remove them and then see if there's a difference but I don't think they can hurt anything if I leave them and they don't look terrible.
So, this is not the final aesthetic, but it is proof of concept. I will seal the entire piece to the door with RTV Black so it's basically invisible.
Old 07-12-2024, 12:06 PM   #9
keep_hope_alive
Electrical Engineer
One clue that there is an air leak in the corner is bubbles forming during a touchless car wash:
My long-term fix was the use of RTV Black along the seam.
Wind noise is MUCH improved, I think I'll remove the winglets now.
noise, seals, turbulence, wind noise, window
