Old 04-09-2024, 04:25 PM   #1
ChibbMD
Drives: 2022 SS 1LE
A Few Questions About Getting A Tune
Hey folks. I've done a few mods to my SS 1LE 6MT and think I'm ready to get my first tune. I've been looking at two options - either my local performance shop (the tech there has a ZL1) or a remote tune from GPI. Regardless of where I get it tuned, I have some questions I was hoping you can help me with.
I've had numerous motorcycles tuned over the years. In those cases, the tune was basically just adjusting the fuel mapping across the RPM and gearing ranges to optimize air-fuel ratio (assuming optimal AFR produces optimal performance).
With the car, my research suggests we're just flashing the ECU with a new tune file(s). The crux of my question is this - Are there different levels of tune or differing variables that need some discussion in advance? Or is a tune just aiming to optimize some variable(s) like AFR? How dependent is the tune on the tech doing the work?
I'm wondering if I need to tell them "Hey, I want max power." or "More power is nice but don't sacrifice my daily drivability."
ChibbMD is offline   Reply With Quote
Old 04-09-2024, 05:14 PM   #2
CalgaryZL1
CalgaryZL1's Avatar
Drives: 2020 Chevy Camaro ZL1
You need to decide which three you want? max power or a daily driver or both. Then except the possible outcome
Old 04-09-2024, 05:18 PM   #3
Baddawg53
Drives: 17 hyper blue 2SS M6
I think no matter which way you decide to go, you need to have an honest conversation with the tuner, and they can guide you through it. If you just have some bolt one the tune should be fairly straightforward, optimizing the new airflow and fuel trims. I'm sure they all have their ways of maximizing power and torque, just make sure whoever touches it is familiar with the Gen v platform.
Baddawg53 is offline   Reply With Quote
Old 04-09-2024, 05:42 PM   #4
cjperformance
cjperformance's Avatar
A good tuner will give max power without sacrificing any driveability. No reason you cant have both.
DSX Aux Low Side | LT4 high side | Flex Fuel
TooHighPsi Port Injection (installed & tuning)
CircleD 3K Stall | QA1 CF Driveshaft
Forgestar F14 Drag 17x10 NT555R2 305/45/17 Rear
Forgestar F14 18x8 NT555G2 235/50/18 Front
10.84@131 w/4.13" pulley
??.??@??? w/3.7" pulley (installed & tuning)
Old 04-09-2024, 06:20 PM   #5
ChibbMD
Drives: 2022 SS 1LE
I like this. Reminds me of the saying - Fast, Reliable, Cheap - Pick 2.
Old 04-09-2024, 06:27 PM   #6
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
A tune in these cars is really just to account for mods. A tune on a stock car is worth zero.
Old 04-09-2024, 06:28 PM   #7
ChibbMD
Drives: 2022 SS 1LE
I think my current set up is relatively simple - MSD IM, 95mm Soler TB, and RotoFab. No internal modifications.
Old 04-09-2024, 06:29 PM   #8
ChibbMD
Drives: 2022 SS 1LE
I'm not chasing big numbers. Just trying to optimize what I've got. First dyno run I did was just with RotoFab. 411hp, 457 torque. Second run added IM and TB, no tune. 427hp and 446 torque. HP increase was above 4800rpm, as expected. Tuner said he thought we might get to 440hp with a tune. I'd be happy with that.
Old 04-09-2024, 06:32 PM   #9
6spdhyperblue
Drives: 2SS 1LE
Changing the intake manifold can benefit from tuning
Old 04-09-2024, 06:59 PM   #10
jlaudio11
jlaudio11's Avatar
Drives: Chevy Camaro
Maintaining the stock camshaft maintains the majority of the engines power profile, intake manifold plays into this a little bit. A tune for your setup should be able to achieve max power without sacrificing drivability. Changing heads, cam and going to an over the radiator ram air intake will change the engines hp/tq characteristics quite a bit and will bring up the drivability issues. Most competent tuners should be able to get you dialed in fairly easily.
'20 Camaro LT1
Twin 67/62 turbo 401(L8t) Texas speed forged piston & rod, BTR stg1 turbo cam, holley ultra lo, port injection, circle d 3600 stall, et street r’s on racestar recluse wheels.
1.33 3.75 5.75@122.98 1/8 pb 9.04@141 1/4 pb technically
'94 Camaro Z28 6mt cc306 cam, 4:10's, longtubes with x pipe, otr intake
jlaudio11 is offline   Reply With Quote
Old 04-12-2024, 01:57 PM   #11
ChibbMD
Drives: 2022 SS 1LE
Does the ECU need to be removed and sent in to unlock it? My understanding was that only applied to the Transmission Unit on automatic models. A local shop is telling me I need to remove the ECU on my manual so they can send it in to someone. That just seemed odd to me given what I've read.
Old 04-12-2024, 02:07 PM   #12
As far as I know, your assumption was correct, the ECM is not locked on our platform, only the TCM for the auto trans (A8/A10) is. Also, I definitely didn't have to pay for any ECM unlocking when Ted Jannetty first tuned my car.
