![]() Drives: 23 Camaro 2SS 1LE Join Date: Oct 2022
I started hearing ticking noise from engine bay after starting the vehicle two days back so took it to the dealership. They said camshaft has been damaged but car has only 4K miles. They ordered the part and said it will be fixed under warranty.
Should I be worried that this happened within the first one year of purchase and please advise whether I need to ask the dealership to check/replace anything else that might have been damages b/c of this issue. Appreciate the help!
Thanks!
Vigg ------------------------------------------------------------ 2023 Camaro 2SS 1LE 6MT 2019 Mustang GT (Sold) 2012 Audi A6 (Sold) 2014 Camaro 2LT RS (Sold) 2011 Acura RL (Sold) 2009 Acura TL (sold) |
![]() Drives: 2023 SS 1LE Sharkskin Join Date: Jun 2023
Wow, that's disconcerting to hear. Do you track the car? What oil do you use and has it been changed in those 4K miles?
ΜΟΛΩΝ ΛΑΒΕ
I didnt track the car. First Oil change was done at the dealership around 500 miles.
The ticking noise started just two days back.
Thanks!
![]() ![]() ![]() ![]() ![]() Drives: 2023 Chevrolet Camaro 2SS 1LE Join Date: Jan 2020
Sorry to hear. Hopefully everything else in your engine is alright. Man I am seeing way too many issues on these boards and the FB groups with the 2020+ cars. I do not feel good about keeping mine long term.
If there is damage on a cam lobe I’d imagine they are also at the very least replacing that lifter.
Current: 2023 2SS 1LE
Prior: 2016 Camaro 1SS 2007 Mustang GT 2008 Civic Si |
#5 | |
![]() ![]() ![]() ![]() Drives: 2024 Riverside Blue 2SS 1LE Join Date: Mar 2016
![]() Drives: 2023 2SS 1LE Join Date: May 2014
Oh no...I have your twin...Do keep us updated on your repair journey at the Dealership...
#7 |
Definitely!
It will take a month for them to fix it(swamped with more repairs is the reason) They are replacing camshaft and lifters. I’m hoping that the replacement parts are not defective ones as I read somewhere that GM replaces damaged camshaft with new ones from same manufacturer.
Thanks!
#8 | |
#9 |
Understood. Appreciate the info!
Thanks!
#10 |
The Dealership opened up the engine and noticed thrust bearing started to fail. Metal debris throughout the engine. Ordered a new engine and has been replaced under warranty. took 3 months to get the car back from them.
Thanks!
#11 |
SoCal Camaro5 Race Team
Drives: 2021 Shadow Grey Camaro 2SS 1LE Join Date: Mar 2010
That sucks. Hope all is taken care of. I have a 2021, built 10/1/2020 and is a M6. Back then I had to worry about the valve springs being bad from a bad batch affecting July- September cars, Camaros and vettes. I have a tech friend check the car I was buying and no recalls or tsb’s, so lucky. I to have a ticking sound but that’s fuel injection noise in the rails, my fifth gen had same. 15000 miles on the car and over three years of autocross 1-2 gear high rpm use and no issues nor any oil consumption.
Guess it was a Wednesday built car..lol |
#12 |
![]() Drives: 23 2SS 1LE Join Date: Feb 2019
That sucks to hear man. Since I plan on keeping it long term this kinda makes me want to get an aftermarket camshaft since my warranty is already voided lol.
Instagram: RideWithDanger
Current Mods: Rotofab, Ported LT2 intake, LT5 TB, Kooks Headers, AWE Touring Catback Radiant Red 23' 2SS 1LE 1100: 11/14/22 | BUILT: 3/16/23 2000: 2/17/23 | 4200: 5/8/23 3000: 2/27/23 | 5000/6000: 5/15/23 |
#13 |
I’m guessing your cam got chewed up so much metal bits got onto the thrust bearing (and most likely the rest of the bearings).
#14 |
![]() Drives: 2019 Camaro 1SS1LE Join Date: Jan 2024
Thrust bearing starting to fail at 4k/mi is a giant (?). One has nothing to do with the other. While metal bits floating through the engine would be bad, it doesn’t just pick on the thrust bearing. I have a LT1 engine in my garage with barely 12k/mi on it (not from my car) thrust bearing was completely sheared off and spun. I’m doing a full 360 thrust bearing on my engine. While the thrust bearing on my car was fine, I did note it seemed to be wearing excessively. The Main bearings were all perfect, just the rear thrust seems to be getting beat up. My car is a manual but I don’t track mine. 17k/mi in 5 years of ownership. The other engine was out of an auto. Never tracked either. Thrust was completely chewed off and spun around the main into the block & cap material.
2019 1SS1LE M6 Shadow Gray Metallic
ProCharger D1X Race Kit - 4.25" Pulley || GPI Pistons/Rods - ACL Bearings - ARP Hardware || LME Timing Chain Guide || Katech C5R Timing Chain || Katech OE Spec Billet Oil Pump || OE Ported Heads || CHE Trunnion Upgrade || BTR 220 Cam - BTR .660" Dual Springs - GM Racing "Caddy" Lifters - BTR 3/8" Pushrods (7.825") || ATI Balancer || LT4 Injectors || LT4 HPFP || JMS BAP || DSX Flex Fuel || LT2 Intake Manifold || LTH (Catless) || Stainless Works Redline Series NPP || 91 + 8oz Boostane 7/26/2024 Tuning in progress |
| Tags |
| 23 2ss 1le, camshaft problems |
