Old 03-19-2024, 05:07 PM   #1
10efrain
Drives: Camaro 2017 1 LT
Lightbulb Check Engine code P103B
Been having this code P103B keeps coming on and off … took it to the dealer and it came back the very next morning… they said nothing is wrong … anyone had it or can point me to a list of codes ? I have a scanner but it seems like the codes are now locker by the manufacturers … smh
Is there a list of all the Check engine light codes I could find ?
10efrain is offline   Reply With Quote
Old 03-19-2024, 08:39 PM   #2
Well, there's https://www.troublecodes.net with a ton of useful information, but this specific code is not covered there unfortunately.
While certain modules may be locked by the manufacturer to make tuning more difficult, diagnostic information isn't, so any OBD-II device should be able to read trouble codes from your 2017.
Old 03-20-2024, 07:42 AM   #3
ctrlz
Bank 1 post-cat O2 sensor is showing sluggish response:
https://www.carparts.com/blog/p013b-...nk-1-sensor-2/
If you have a sensor socket, probably not hard to replace.
amazon has some cheap ones:
https://www.amazon.com/Apeixoto-Oxyg...1zcF9hdGY&th=1
Old 03-20-2024, 09:10 AM   #4
Z28GTOSSMike
Drives: 2019 Camaro 1SS
Word of warning. I replaced one of my O2 sensors with an aftermarket one that was readily available and had to replace it just a few months later. Used OEM the second time and no more problems. I have used aftermarket ones in the past but it bit me in the ass this time.
Z28GTOSSMike is offline   Reply With Quote
Old 03-20-2024, 11:08 AM   #5
ctrlz
Agree. I would go OEM for an O2 sensor.
Go cheap on the socket (amazon or harbor freight), as you will rarely use it. They also make offset sockets. Not sure how hard it is to reach, but usually the post-cats are easier than the pre-cats.
Old 04-08-2024, 04:40 PM   #6
10efrain
Thanks everyone I got a buddy to help change it I guess I’ll just replace both after cats since I’m not sure if it’s left or right …. Didn’t pass emissions inspections here in Jersey thanks to it I believe, the code comes and goes but hopefully is just that car runs perfect …I’ll update soon.
Old 12-30-2024, 05:36 PM   #7
10efrain
It didn’t work out for me… the code came back a few weeks after changing both o2 sensors after cats … car still runs normal…
Old 12-31-2024, 07:23 AM   #8
ctrlz
Leaky fuel injector?
