Old 03-16-2024, 12:09 PM   #1
L2SS455
L2SS455's Avatar
Drives: VOM 2022 2SS
Angry Okay, GM it's time you fixed this! JLR did.
Sixth-Gen Camaro Theft Is Soaring–the Reason Is Simple
https://ls1tech.com/articles/sixth-g...son-is-simple/
By Derin Richardson - March 7, 2024
L2SS455 is offline   Reply With Quote
Old 03-16-2024, 01:39 PM   #2
Desperate times (should) call for desperate measures.
Old 03-16-2024, 02:31 PM   #3
MT-SS1LE
Drives: 2023 SS 1LE Sharkskin
The same company sleazy and dishonest enough to sell their own customer's data without consent? I doubt they will be in much of a hurry to help us out.
ΜΟΛΩΝ ΛΑΒΕ
MT-SS1LE is offline   Reply With Quote
Old 03-16-2024, 02:49 PM   #4
Vtor_ZL1
Who Needs to KNOW?
Vtor_ZL1's Avatar
Drives: 18 ZLE
So.. where do we get dummy port that sorta function legit but passes no data, just shows power.. and real one tucked under dash ?
ing for grip.
http://www.motorsportsne.com/
Old 03-16-2024, 03:28 PM   #5
Number 3
Hail to the King baby!
Number 3's Avatar
Pretty sure there is consent. The real issue to me is that they aren’t transparent about what it means to opt in or opt out. For example is it buried somewhere that you are in unless you specifically do something to opt out? But pretty sure they aren’t selling data without consent.
I know when I worked there I couldn’t get data unless the customer and location was stripped off and even then it was an act of god. And my job was managing customer usage data lol.
Old 03-16-2024, 03:30 PM   #6
Vtor_ZL1
Who Needs to KNOW?
Vtor_ZL1's Avatar
Drives: 18 ZLE
"Oh yeah, Smart Driver, i want that"... not knowing your driving habits, gps data, etc are all being fed back to GM who goes n sells info to your insurance company.. YIKES!
Sucky part.. YOU pay for onstar.. and its still FKS you! So you're paying to get fkd.
ing for grip.
Old 03-16-2024, 05:43 PM   #7
L2SS455
L2SS455's Avatar
FYI,
Lee Walton, head of JLR's Vehicle Theft Reduction Group, told us that the next step for thieves was to utilise automotive locksmith equipment, enabling them to programme keys to vehicles. By plugging a device into a car’s diagnostic port, a key can be programmed in a matter of seconds allowing the car to be taken. This type of theft is commonly known as a ‘BCM hack’. The only hurdle for criminals being that the car must be unlocked.
More high-tech equipment was therefore required. A signal jammer is commonly used, preventing owners from being able to lock their vehicle. Walton told us that these are regularly used in car parks or petrol stations. Once the owner leaves the vehicle, thieves are able to jump in and take it.
For vehicles that are locked, a more invasive method is used. Crime gangs worked out that they could trigger a vehicle’s locking system by intercepting the on-board computer wires and sending fake messages. This type of attack requires highly sophisticated knowledge of a vehicle’s electrical architecture. The equipment costs upwards of £25,000. Depending on the vehicle, these wires are usually accessed by cutting holes in either the front wing or bootlid.
JLR has been rapidly working on software updates to prevent these attack methods. Vehicles dating back to 2016 will be eligible for free updates, with rollouts taking place now. The software update prevents keys being programmed by the BCM hack method and also stops external devices from being able to send commands to the car’s computer system.
Old 03-16-2024, 08:05 PM   #8
Vtor_ZL1
Who Needs to KNOW?
Vtor_ZL1's Avatar
Drives: 18 ZLE
JLR insurance in UK is getting so high (due to theft / vandalism) that it's causing value of cars to PLUMMET and cars becoming uninsurable.
There's BBC? video about the topic that was on YT recently.
ing for grip.
Old 03-16-2024, 08:34 PM   #9
Number 3
Number 3's Avatar
But I believe the fix for this would require you to go to a GM dealer if you ever needed a replacement key programmed for the car? Can anyone predict the thread on why GM dealers charge $600 plus for a new key?
And the article does touch on the lack of law enforcement and the difficulty in getting prosecution as GTA. It’s easy, the punishment is minimal and it’s mostly upside for criminals. None of hat is GMs fault.
Old 03-16-2024, 09:06 PM   #10
L2SS455
L2SS455's Avatar
I would gladly go to the dealer, if I ever needed a replacement key programmed for the car. I've owned vehicles since 1974 and have never had to do it yet though. Even if cost $600, it's less than a minor insurance deductible. When the car is worth $40+ grand!
This is a GM problem that needs fixing Now. Hell, I got AOL email demanding two-step verification just to use E mail now. GM like most companies are selling technology. It's time they start acting like it and they need a security fix for their customers.
Old 03-18-2024, 10:22 AM   #11
L2SS455
L2SS455's Avatar
If you are a 6th Gen. Camaro owner, you need to do this today.
Call GM customer service and demand an security Update 1-800 222-1020. Just like JLR did for it customers for new and older vehicles. I have. If they get enough complaints that might just help us out. Even with thousands spent on security prevention we get broken windows due to this issue being know via tiktok.
Old 03-18-2024, 10:54 AM   #12
paudea4
Drives: 2017 Camaro 1SS Convertible
Called today and made a complaint
paudea4 is offline   Reply With Quote
Old 03-18-2024, 12:36 PM   #13
Capricio
Drives: 2000 WS6
I made a parts list in the DIY section. You would only need a couple of positaps, a dummy OBD with the correct clip profile, and the 10k resistors (optional) to do what you're describing.
Capricio is offline   Reply With Quote
Old 03-18-2024, 12:52 PM   #14
olrocker
olrocker's Avatar
Drives: People crazy with my sexiness
1. Don’t loose your keys!
2. Camaros aren’t “cheap” cars, so parts should not be expected to be cheap if you can afford one…. Which leads me to
3. Ever price check a new transponder from Mercedes? Your eyes will water. So if it’s $600 for a Camaro that’s not so bad.
There’s plenty of F-Body Camaros out there if you want a Camaro but are worried about the price of a key
Purchase order submitted on 6/23/23
Received and purchased 9/8/2023
2024 2SS 6MT coupe
Sharkskin/Light gray
Moonroof/Navi/NPP/Mag Ride/Red Brake Calipers
Gray painted split spoke wheels
Illuminated footwells/illuminated bowtie
olrocker is offline   Reply With Quote
