#1 | |
Show me your Garage Floors for Camaros
I'm looking at a Polyurea system which is supposed to be a lot better than Epoxy. (not going tiles)
I need ideas on colors or even Camaro related logos in the floor. Here's a video of what I'm planning... Show me what you have |
Moderator
I did a “granite” style look on mine. Been a few years and still love it. No Camaro logo though lol!
NYTMARE23
Drives: Black 2023 ZL1 A10 Join Date: Oct 2022
Best decision I made was having a poly floor done in our garage! Looks great, durable...WAAY more so than epoxy, and easy to clean!
SORRY for the sideways pics!!!!![]() ![]()
2023 A10 ZL1 "NYTMARE"
#4 | |
Moderator
![]() Although your coating gave your car Spider-Man powers…damn…
#5 | |
NYTMARE23
![]() .Those spider powers are something else, let me tell you!! ![]()
#6 | |
Moderator
#7 |
![]() Drives: 23 ZL1 20 GC Altitude Join Date: Aug 2020
I have a Poly floor that looks like the two above. Only been down for about 6 months but it is great!
23 ZL1-A10-Summit White
#8 |
Gray Ghost
Drives: 24 Camaro 2SS Loaded Join Date: Feb 2024
Super easy to clean! Makes it actually a usable room! Do not know why it loads sideways I can’t get it turned!
#9 | |
Moderator
#10 | ||
Who Needs to KNOW?
Here's our fix:
Part 1: Part 2: We chose a nice, bright color to make place brighter and less likely to loose gray bolt that falls to the floor. It's SOOOO much easier to clean than bare concrete. Sweeping is effortless.
#11 |
![]() Drives: 2016 SS Join Date: Oct 2019
I put epoxy down about 10 years ago, and I'll never have a bare concrete garage again. Night and day difference. Not saying Poly isn't better, as I've never done any research on it, but how much better could it possibly be? It's a floor. Just sweep and it's clean. I hose it out once a year or when a big job gets it dirty. It repels brake fluid, so I don't see how much more durable you'd want. Still....not saying poly isn't better. Maybe it's cheaper? Easier to apply?
EDIT* -So I wanted to edit as not to add MORE posts that weren't directly related the the original question, but I DID feel this info may be helpful. -Polyurea is technically stronger, but it's more about marketing, as both are more than strong enough to handle all but the most abusive types of use. BOTH will fail if not put down properly. -Poly sets up faster, so it can be less of a hassle for customer and installer, but again marketing as it's a one time inconvenience having to clear out the garage. Poly can be finished in a day, where epoxy takes 2 or 3. -Poly will not fade due to UV. Once again marketing though, as most epoxy won't see enough UV to make a major difference in color fade or yellowing for many many years, and unless you don't do WORK in your garage, the general wear and tear will show far more than any fading. -Most poly primers don't give moisture protection like Epoxy. Some do, and sometimes it's not needed. Discuss with your installer. -Both will fail if not properly installed, and both will be more than you'll ever need if installed correctly. Poly does have less potential for issues, should the floor be put down improperly, but again marketing. Your installer should have no problem installing EITHER primer, and you should have warranty on EITHER type from your installer, should problems arise. After an hour of research, it does seem as though poly isn't a bad choice. My wife and I are hoping to move into what we hope is our "last" home in the next year or two, and I'll definitely take a good look at poly for my garage floor. That being said, I watched 3 back to back videos where the professional installers all said they preferred poly, but it almost always came down to the time. They can get it done faster, and the customer liked that they can move their belongings back into the garage faster. Most of the other "benefits" weren't really a concern, and didn't largely impact the decision. Anyhow, interesting topic. I put down a DIY epoxy job in my current garage 10 years ago and it's been great. No issues at all. Still, I'll definitely look at poly when the time comes for another floor. Last edited by Abubaca; 03-16-2024 at 09:20 AM. |
#12 | ||||||
https://mail.google.com/mail/ca/u/0/#inbox Quote:
![]() Quote:
Seems it's more difficult to put down since it drys so fast and a couple $$ per sq foot more expensive but this is my forever house so might as well do it right. |
#13 | |
NYTMARE23
![]() Also as a side note...have had the race ramp Flatstoppers now for 2 years and are very pleased with them. Car sits on them from October-May each year and have had NO flat spots . I know there are probably people that don't use them and don't get flat spots but the cost of tires was/is not worth the risk to me.
#14 | |
Is that a lift they are working around? It never did really show. |
