![]() Drives: 2016 2SS Convertible Join Date: Dec 2019
Auto shutdown?
Fired up the in-storage SS yesterday (had to jump it since I haven't run it all winter, didn't have it on a charger and forgot to put it in transpo mode). I was letting it run awhile to charge the battery and went inside. Went out a few times and it was still running, until about 45 minutes to maybe an hour after last doing anything with the go pedal, and it had shut itself off! All systems shut off just as if turning it off normally. I did have the keyfob in my pocket so it wasn't in the car while running. It started right up again with no codes and no issues. Wondering if there's some sort of auto-shutdown function programmed in that shuts if off after xx time with no actions by a driver? Couldn't find anything in the manual.
Hyper Blue/Ash Gray A8 Magnetic Ride Control Dual Mode Exhaust 2019+ version Split Spoke Silver Wheels Navigation Silver Rally Stripes |
![]() ![]() ![]() ![]() ![]() Drives: 2023 Camaro 1SS Join Date: Apr 2014
I know it's mentioned in my 2023 owner's manual. The car will shut off after 30 minutes of idle runtime if you leave the key in it. 15 minutes without the key.
Idling isn't a great way to charge the battery....I'd recommend you buy a charger/maintainer at least 4-5amp and charge till full and keep it on while the car is in storage if at all possible. |
![]() Drives: 2016 1LT 'Vert Join Date: Feb 2022
Most likely. I never tried it but I though it was 10-15 minutes. The delay time may vary over products and model years....
I also thought a lot of vehicle imputs would "reset" the counter, like opening a door or tapping the brake pedal, but I could be thinking of RAP. Back when Volt was around, GM had incidents of people parking their Volt in a garage and leaving with out turning it off. When the battery became depleted, the ICE generator would start, and run the vehicle out of gas too, with all of that exhaust holed up in the garage. So gm implemented an off-timer that will turn the Volt off after a certain amount of time in PARK with no other input. They carried over the functionality to ICE vehicles. I think the work around is to put it in "N" with the park brake set for automatics. Not sure for manuals... |
![]() ![]() ![]() ![]() ![]() ![]() Drives: '17 Camaro 2SS & '99 Camaro Z28 Join Date: Feb 2014
You need a trickle charger.
As for a idle shutoff, yes they will shut themselves off if they are left in park and idling without moving. My SS shuts itself off aftrr about 30 minutes of idle time in park. |
#5 | |
![]() ![]() ![]() ![]() Drives: 2020 Camaro 2SS A10 Join Date: Jun 2018
2020 Camaro 2SS A10 | Rebuilt by: CBI Street Cars | 2" SE LT Headers | 3" SE X-Pipe | 3" MBRP Axle-Back | Pri & Sec Cat Deletes | Roto-Fab CAI | LT2 Ported | 95mm ZR1 TB | LSA crankshaft conversion w/modified crank gear | LS1 thrust bearing | LS MSD Plug Wire Set | BTR Stage I Cam | ARP Rod Bolts | Delphi Lifter set | NGK LTR71X-11 spark plug set | DOD Delete | VVT Limiter | ECM, TCM & E85 | Retuned by: Justin L. | Dyno: 510 rwhp 472 rwtq | Best 1/4 Time: 11.639
