It's in the hole!
Drives: '11 2SS L99 SGM, '18 2SS, M6, HWSE Join Date: Apr 2011
TR6060 Question
First, I am very familiar with both the T56 and TR6060 having had several Camaro's and 'vettes with these over the past several years. I am no stranger to the 1st to 2nd grind but the 2ss I picked up a week ago is different. A handful of time already it has kicked out of 2nd when I let the clutch out. This is a synchro problem or someone has tried to force it into 2nd when the 1st to 4th is engaged? I put skip shift in last night and will probably change the fluid in the next few days. Most of the time this is maybe the smoothest 6060 I've experienced but sometimes it will not go "all the way" into 2nd gear and this is when it pops out when you let the clutch out.
Any help or advice here would be appreciated. Fluid suggestions too, I am leaning toward Royal Purple but in the past have used Redline. This car is 100% stock except for the skip shift I just installed. This car is just a cruiser for me, I don't plan to track it or beat on it in any way. Thanks in advance for your advice. |
Probably doesn't like you
Drives: 2022 WCT ZL1 M6 Join Date: Jun 2015
Never had any issues in 20k with my '17 2SS, nor the Tremec in my '16 C7 (~14k miles).
I did switch to Royal Purple when I bought the SS (bought used), and at 1500 miles on the C7 (bought new)
كافر ΜΟΛΩΝ ΛΑΒΕ железобетонное очко Quod gratis asseritur, gratis negatur. There is an unequal amount of good and bad in most things, the trick is to work out the ratio and act accordingly. |
![]() Drives: 2018 Hyper Blue Metallic SS 1le Join Date: Oct 2023
my 2018 1le does this, but pretty much only when cold...
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 23 ZL1 A10 Rapid Blue Join Date: Aug 2020
I don't recall having an issue like you described in my 18 1LE.
![]() Drives: 2024 Camaro 1SS M6 Join Date: Nov 2023
IIRC there was a thread about this very issue not that long ago, I think the user ended up taking it to the dealer for warranty service any there was indeed a problem with the synchros.
My '24 SS hasn't had any problems, it shifts like butter. As I understand it the skip shift (at least for the last two model years) is only a nanny indicator on the dash and doesn't actually lockout 2nd gear. That's been my experience with the car thus far at ~500 miles. I was planning on investing in a skip shift eliminator but it doesn't seem necessary. |
![]() Drives: 6th Gen LT1 Join Date: Jun 2023
I know we like cars and most people here in this forum that buy a manual knows how to shift, but that's not the case for the rest.
Most manual transmissions are going to have problems more related to bad shifting than hard driving. Not pressing the clutch all the way, skipping gears, bad down shifting, grinding, forcing the shifter, resting the hand on the shifter etc. etc... If the shift pops out, it means the engagement teeth are ground and lost the retaining angle. This slight angle, under load, pushes the gear inwards to keep it engaged. if its flat or worn out and the angle is lost or reversed, it pops out.
#7 |
![]() Drives: 2023 Camaro 1SS M6 Join Date: Mar 2023
When the car is cold this trans is definitely notchy (at least with stock fluid). The first few 1-2 shifts can be rough, but I don't force it. Sometimes going back to neutral helps.
There's a difference between a gear being fully engaged, and then it pops out, as opposed to it never really going fully into the gear in the first place. As I said, I've definitely had it not want to fully go in, but I don't let the clutch out, otherwise I could see how it won't engage right.
Black 2023 Camaro 1SS Coupe M6
Ordered: April 2022-----Built: July 2022-----Delivered: September 2022 -Dual-Mode Exhaust (NPP) -Red Painted Calipers (J6F) -5 Split Spoke Bright Silver Painted Aluminum Wheels (56W) -Chrome Camaro Logo Fender Badge -Second Generation Front Splitter in Satin Black |
#8 |
It's in the hole!
I would say my problem occurs when it doesn't go fully into 2nd, even though it feels like it did. I hope that makes sense, and I am trying to be extremely careful to make sure it is in gear before letting the clutch out and not "force it" into gear either.
I do have a 90 day warranty from Carmax and may pursue it with them if it continues to be a problem that I can't solve on my own. And again it is only on 1st to 2nd and cold is worse but it can happen once warm if I'm not careful. |
#9 |
![]() Drives: '23 2SS RSblue 6MT, sold '19 ND2 Join Date: Dec 2021
When its cold, I have the issue where it doesn't wanna go in - but usually that only happens once during the drive cycle, if at all. Skip shift has been installed since new. It feels like it is being stopped from going in, but I never force it. Usually I will go back to neutral and double clutch or hold the clutch longer and it will go in. I have an SS and it seems to take a while for the transmission to be fully warmed up. I'm not sure if that's because of the extra coolers or fluid. I think there is better fluid that can help like Redline d4.
'23 2SS, 6 speed, NPP, Copper-free brakes, 56V Carbon Flash Rims, Riverside Blue
1LE sway bars EOS front splitter 5-6-22:1100, 7-19-22: 3000, 8-3-22: TPW 8/15/22, 10-4-22: ETA 10/13/2022 10-15-22 6000 |
#10 | |
#11 | |
![]() ![]() ![]() ![]() ![]() Drives: 2023 Chevrolet Camaro 2SS 1LE Join Date: Jan 2020
before you drive off.
Current: 2023 2SS 1LE
Prior: 2016 Camaro 1SS 2007 Mustang GT 2008 Civic Si |
#12 | |
![]() Drives: '18 ram 1500 Join Date: Dec 2016
My 23 ZL1 definitely has the 2nd gear lockout, I put in the skip shift eliminator first week I had the car.
2023 ZL1 Radiant Red 6 spd, pdr, carbon fiber hood
1100 10/28/22 2000 12/6/22 3400 12/17/22 TPW 1/9/23 delivered 2/7/23 |
#13 |
#14 | |
Yeah it's there. The message will stay on for a bit even after you pass the lockout window, so you could just be missing it.
