Old 03-10-2024, 12:15 PM   #1
Catalin
Drives: Chevrolet Camaro 6th gen 6.2 v8
Exclamation Audio problems
I had a bottle of alcohool in the trunk and it broke and the systems went off, i changed the fuse boxes and then it worked but the navi not. I changed the amplifier(bose) and now everything works just fine except the sound system, only one speaker works, the one on the driver side but it sounds horrible, i don t know what to do. Any ideas?
Catalin is offline   Reply With Quote
Old 03-20-2024, 06:13 PM   #2
Callaway SC630
Callaway SC630's Avatar
Drives: 2020 Callaway Camaro SC630
Can you get a speaker and tap into that side and see what that tells you?
2020 Callaway Camaro SC630 - MN6 1SS Satin Steel Gray
2019 Callaway Corvette SC757 - MN7 1LZ Elkhart Lake Blue
Callaway SC630 is offline   Reply With Quote
Old 03-22-2024, 04:16 AM   #3
Catalin
What do u mean bytap into that side?
Old 03-22-2024, 07:55 AM   #4
keep_hope_alive
Electrical Engineer
keep_hope_alive's Avatar
Drives: 2023 1SS A10 Black
we need some photos of the trunk components. the more photos the better.
Daily Driver mileage update: 64k mi. @ Apr 2026
Old 03-23-2024, 09:09 PM   #5
Callaway SC630
Wire a speaker using those wires and it will tell you if you have a bad speaker or a wiring issue. Just a good place to start.
Yes, photos would help.
Old 09-28-2024, 03:18 PM   #6
shenandoah
Drives: 2014 Camaro and 2018 Silverado
Any more info on this?
2017 2SS only have audio in driver door speaker
Thanks
shenandoah is offline   Reply With Quote
Old 09-29-2024, 08:13 AM   #7
ctrlz
Start by looking at the bottom of the trunk for water ingress.
You have 2SS with Bose, and all the speaker connections are in the trunk at the amp.
Old 10-18-2024, 02:23 AM   #8
Catalin
My trunk is dry and no water ingress
Old 10-19-2024, 03:20 PM   #9
truckrglenn
truckrglenn's Avatar
Drives: Chevy camaro
Thanks
Did you add a subwoofer with a different harness? I forget who, but one company states that if adding a subwoofer to a non-Bose amp using their harness, you'll lose sound in one of the sides. I forget which side of the car that they mentioned.
Glenn
SOLD - 2017 Camaro 2LT RS Convertible
2017 GMC Arcadia Denali
truckrglenn is offline   Reply With Quote
Old 10-21-2024, 04:57 AM   #10
Catalin
i didn t add anything, from what i ve searched online i need to reprogram it but the problem is in romania there is no chevy auto dealer or service
does anyone know how to long code it or where i can find the code?
Old 10-24-2024, 07:19 PM   #11
gblaue
gblaue's Avatar
Drives: 2017 Bright Yellow ZL1 6spd
How did you obtain a replacement amplifier? Did you order the correct amplifier from GM by the VIN#? It sounds like you got the wrong amplifier.
2017 ZL1 Bright Yellow w/ black center stripe, 6 speed, CF gas door, PDR, Navi
gblaue is offline   Reply With Quote
Old 12-12-2024, 10:30 PM   #12
BadA$$LS3
Drives: 2013 Camaro 2SS/RS. 2016 Camaro 2SS
Thanks
I’m having the same issue only have audio in the driver side door speaker in my 2016 2SS was wondering if you resolved this problem? Any help would be greatly appreciated thanks.
BadA$$LS3 is offline   Reply With Quote
Old 01-23-2025, 09:43 PM   #13
BadA$$LS3
Anyone ever had only 1 speaker work in the car, no turn signal audio, no door chime, and if someone calls on the phone, no audio comes through? What did you do to fix it?
camaro6. speakers. bose.
