![]() Drives: '23 Riverside Blue ZL1 convertible Join Date: Feb 2023
timing of oil changes
At what % remaining oil do y'all have it changed at?
Snackbar Tuning
Drives: 2023 SGM ZL1 Join Date: Oct 2016
When it drops under 10% I start planning to change it in a weekend or two. 10% comes a lot faster when you run E60+.
GM Gen V Calibrator
20-25%
![]() Drives: 2024 Camaro 1SS M6 Join Date: Nov 2023
Given the weather in my area, I doubt I'll drive it enough to get close to the oil change internal, so my plan is to change it yearly before I put it away for the winter.
Having FUN in the SUN...
![]() Drives: 2022 M6 ZL1 1LE Join Date: Jan 2022
I was told every 2K miles running running E60, which for me... is about once every 10 months or so.
![]() ![]() ![]() ![]() ![]() Drives: 2020 Chevy Camaro ZL1 Join Date: Apr 2023
I changed mine right when I parked it for the winter, curious to see what it shows after 6 months of storage.
#7 |
![]() Drives: 2023 Camaro ZL1 Join Date: Jun 2023
I'm planning on doing mine twice a year regardless of miles or oil life %. I changed it yesterday before firing it up for the first time this year and I'll probably do it again mid summer. Considering I drive it about 6,000 miles a year it should be about every 3,000 miles. It might be a little more than necessary but its relatively cheap and easy maintenance to make sure I keep the engine running smoothly.
First Time Camaro owner. 23 ZL1 Black A10
#8 |
At 10% I start planning to change it
#9 |
![]() Drives: 2019 ZL1 "1LE" | 16 SS | 2017 F30 Join Date: Dec 2021
between 2500 - 5000 miles. Depending on how aggressive I drove since last oil change. Oil degrades quick at 270°F.
Callaway SC750 ZL1, DIY 1LE with added OEM 1LE Wheels, DSSV Suspension and 1LE Aero, FEA front control arms, DIY oil cooler, CWA 150 pump, bigger intercooler, BMR lockout kit, CTSV Brake Air Deflectors, Smooth idle cam, LS7 lifters, CHE trunnion bushings. Tuned by JRE
#10 |
Probably doesn't like you
Drives: 2022 WCT ZL1 M6 Join Date: Jun 2015
Spring and Fall. I drive 5-10k / year.
كافر ΜΟΛΩΝ ΛΑΒΕ железобетонное очко Quod gratis asseritur, gratis negatur. There is an unequal amount of good and bad in most things, the trick is to work out the ratio and act accordingly. |
#11 |
NYTMARE23
Drives: Black 2023 ZL1 A10 Join Date: Oct 2022
I do mine yearly around August/September time frame since I put it away for the winter from October-May each year. I only put 328 miles on it last year and only have a total of 763 miles on the car, but was TOLD I should AT LEAST change the oil yearly even though I don't drive it more than 1,000 miles per year since the oil viscosity can still break down over a TIME period? Maybe I don't NEED to?, but better safe than sorry I guess.
![]() ![]() Just trying to figure out now if I should do the diff fluid at 1,000 or if I'd be good to wait until 1,500???, which could be 3 years from now! ![]() ![]()
2023 A10 ZL1 "NYTMARE"
#12 |
![]() Drives: 2023 Camaro ZL1 Join Date: Jan 2016
I follow the oil life monitor in all of my gm cars.
So usually I make an appt at about 10%. Back when I had a new 4th gen ls1 camaro I had blackstone labs do an oil analysis. Their recommended intervals were dead on with what the gm ecu was telling me. Have things changed? Maybe. But even expensive oil changes are cheap in the long run. |
#13 | |
![]() Drives: 1974 Z28, 2002 Camaro SS 2024 ZL-1 Join Date: Aug 2008
so $125 or so for an oil change using Mobil 1 Supercar synthetic (or whatever brand you prefer) is cheap. I've found it best to never skimp on your engine oil.I have a couple of cars that only get driven hundreds of miles (or less) per year and I religiously change the oil once a year, preferably in the fall before they are put away for the winter. You don't want to store a car for months during the winter with dirty engine oil in it. |
#14 | |
NYTMARE23
