![]() Drives: ´18 ZL1 A10 Red Hot 😍 Join Date: Jan 2016
Hello,
I need help with my next mod... Right now I have ATI down pulley +10%, 1-7/8 headers, Big gulp, 95mm throttle body, 2" exhaust catless, FI interchiller w/ CWA400 pump and spacer plates, Elite catch can and PWR oil kit w/ sandwich plate. Here we can use 93 pump gas, impossible to use flex fuel because it is not sold in Spain, and I am will not do mods to the fuel system or a cam upgrade. Car is for weekend use and 3 or 4 times per year road racing. The idea is to send the supercharger to Kong and have it returned to me along with a 103mm TB, but the question I have is whether to use the standard porting or also select the "Stage X". Knowing the mods made to the car I guess I won't have an 800rwhp car if I don't add fuel modifications, but I don't need that much power, I'm satisfied if I reach 680rwhp. I'm still in doubt about who is going to do the tuning because it must be done remotely, that´s why I'm asking you for advice so I can go with a final build to the tuner. Thank you!
First ZL1 in Spain (Madrid)! Red Hot, A10, PDR, carbon fiber hood & grounds effects...
![]() Last edited by Akura; 03-08-2024 at 06:43 PM. |
Moderator
For your power level, standard porting is fine.
Catch up with Megahurtz or KingLT1 on this board for tuning. Both great guys.
#3 | |
Moderator
Snackbar Tuning
Drives: 2023 SGM ZL1 Join Date: Oct 2016
The regular port with the 10% lower will hit harder because air velocity doesn't slow down as much in lower rpms. But the X port will pull much harder after 5500 RPMs.
So it depends on what you do with the car and how you drive. The X port shifts the powerband to the right.
GM Gen V Calibrator
#6 | |
![]() Drives: BLUE CAMARO ZL1 1LE M6 Join Date: Jun 2009
To reach your goal low side fuel will need a boost from a JMS fuel system voltage booster. Have you considered Jokerz for porting? Producing 680 RWHP on pump 93 is going to be a challenge as these engines are Knock limited and more boost makes that problem worse. Dyno numbers are not street/track numbers. I offer remote tuning services world wide. Ted.
www.jannettyracing.com
Celebrating 39 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705 email tedj@jannettyracing.com |
#7 |
![]() Drives: ZR1 Join Date: Sep 2013
X PORT
I would do the XPORT well worth the money and it sounds so damn good with the whine being louder.
