Old 03-08-2024, 01:02 PM   #1
kjhowell75
Drives: 2021 Camaro ZL1 A10
LT4 Supercharger Slanted Intercooler Brick Inquiry
Good Afternoon Camaro6 Team,
I know PWR has aftermarket LT4 Supercharger Slanted Intercooler Bricks on backorder and at a cost of almost $1600. One of my factory bricks developed a leak (not at the seal but rather the rear fin) and wanted to but a feeler out if anyone had a used factory brick who has already upgraded or could point me in the right direction. GM does not have a part number for the individual bricks rather they want you to buy a complete supercharger manifold.
Thanks in advance!
Ken
kjhowell75 is offline   Reply With Quote
Old 03-08-2024, 03:36 PM   #2
CalgaryZL1
CalgaryZL1's Avatar
Drives: 2020 Chevy Camaro ZL1
Due to lack of response, I am guessing you have a rare failure. How were you able to realize the issue? Were you seeing stuff out of the tailpipe, was your circulation pump shutting down putting the car in limp mode?
Old 03-08-2024, 05:39 PM   #3
Dan82679
Dan82679's Avatar
Drives: 2017 ZL1
Thanks in advance!
Ken
I have 2 slanted supercharger bricks available.PM me for more info
Dan82679 is offline   Reply With Quote
Old 03-08-2024, 09:17 PM   #4
kjhowell75
I noticed the leaking Intercooler brick with a flashing check engine light that was diagnosed as a random misfire; I also noticed that my aftermarket S/C Coolant reservoir was constantly becoming low. When I pulley the S/C off and inspected, I noticed a large amount of coolant within the intake ports. Diving into the motor and pulling the Driver's side cylinder head off, cylinders 1 and 3 were almost filled with coolant. Could have easily hydro locked the motor as coolant does not compress!
