Old 03-07-2024, 01:51 PM   #1
zx9rmal
zx9rmal's Avatar
Drives: '20 ZL1 M6
Oil filter confusion
I couldn't get the search page to load. I got an AC Delco PF64 oil filter from Amazon. On the filter is #12706595. When I did a look up for AC Delco, the
PF 64 # is 19386865. What gives?
Mal
Ft. Lauderdale, FL
'20 Camaro ZL1 M6
'22 Kawasaki ZX-14R
zx9rmal is offline   Reply With Quote
Old 03-07-2024, 01:57 PM   #2
cdb95z28
cdb95z28's Avatar
There's been updates to the PF64. As long as it says PF64 it's good. The PF64 I have is 25206377!
No worries, send it!
"KEEP THE FAITH"-Fbodfather
cdb95z28 is online now   Reply With Quote
Old 03-07-2024, 02:44 PM   #3
GM changes the PF64 filter more frequently than one changes their underwear. I am aware of at least two "update streams", see below, the final SKUs of which (25206377, 19419226) are both marked as available:
12640445 -> 12696048 -> 12706595 -> 25206377
19386865 -> 19419226
No idea what the differences among them, if any, are, I suspect supplier changes and the use of ever cheaper materials.
I loved the original 12640445 filter, by the way, it was sturdier, thicker and looked more robust.
Last oil change I used an Amsoil filter (EA15K50) along with their oil. Yes, I know it's 3x more expensive than these ACDelco filters, but boy, does it look and feel way more solid, and at $5 vs $15, nobody cares about the higher price (let the flame war begin ).
Old 03-07-2024, 03:14 PM   #4
CalgaryZL1
CalgaryZL1's Avatar
Drives: 2020 Chevy Camaro ZL1
As long as you have close to a 22 psi bypass rating for the filter any quality brand will be ok.
Old 03-07-2024, 03:22 PM   #5
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
This.
I am doing something similar. I started (last oil change) using their oil and filters in their service kit (for lack of a better term), instead of the Mobil oil and Delco filter I was using.
'20 ZL1 Black "Fury"
Old 03-07-2024, 03:26 PM   #6
zx9rmal
zx9rmal's Avatar
Drives: '20 ZL1 M6
Thanks guys. This is crazy. Isn't there also a "longer" version of the PF64. UPF64R??
Mal
Ft. Lauderdale, FL
'20 Camaro ZL1 M6
'22 Kawasaki ZX-14R
Old 03-07-2024, 03:29 PM   #7
zx9rmal
zx9rmal's Avatar
Drives: '20 ZL1 M6
On another note, I'm having myM6 fluid changed today. What is the reason for the level to be 1/8 below rather than at the bottom of the fill hole?
Mal
Ft. Lauderdale, FL
'20 Camaro ZL1 M6
'22 Kawasaki ZX-14R
Old 03-07-2024, 03:30 PM   #8
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
More is not always better
Yeah but you certainly don't want a UPF64R (35psi bypass) and probably also don't want to dangle any precious bit of engine kit down below the pan where the speedbumps et al will remove the end of it in an unscheduled and violent fashion.
Old 03-07-2024, 05:03 PM   #9
Fenmore
Drives: 2017 Camaro ZL1
Which Amsoil oil did you go with? I was gonna switch on my next change as well.
Fenmore is offline   Reply With Quote
Old 03-07-2024, 10:22 PM   #10
I use Amsoil Signature 10W-30 with my mods (see them below).
Old 03-08-2024, 10:31 PM   #11
discgolf01
Drives: 2018 ZL1 Convertible M6
This might help, this is the official GM communication:
https://gmserviceinsights.com/new-ac...d-performance/
discgolf01 is offline   Reply With Quote
Old 03-08-2024, 11:09 PM   #12
JSH
JSH's Avatar
Drives: '20 ZLE
https://drivenracingoil.com/c-138947...l-filters.html
LME uses Driven filters here
2020 ZL1LE A10.
LME LT4 390 short block, CID Heads, Kong E2650, FBO.
15" conversion, Nitto 555Rii or MT ET Street R or Toyo Proxes RR.
100 octane: 1045hp/1055tq.
100 octane + Alky MAF Meth (1) 10+:
Old 03-09-2024, 11:07 AM   #13
getchapull
TEXIT
getchapull's Avatar
Drives: 2019 ZL1 M6
The Wix WL10290XP oil filter is well made and has the correct bypass (22) PSI for the LT4 engine.
Added bonus: it's painted black to match my car!
getchapull is offline   Reply With Quote
