Old 03-07-2024, 08:01 AM   #1
E75
Drives: Challenger R/T
Door window not touching?
Hi guys. Last few days I noticed the driver side window had some wind noise on the highway. Yesterday on thy way home I noticed it getting worse.
After I got it in the garage I noticed the driver-side window is cocked out, to the point it does not even touch the rubber seal in back... anybody ever had this before? I added pics with the passenger side for reference...
E75 is offline   Reply With Quote
Old 03-08-2024, 04:18 PM   #2
Bumbleboy92
Long hauler
Bumbleboy92's Avatar
Drives: 2022 Camaro 2SS 1LE
Looks like the window didn't index, I've had it happen once where the door opens but the window doesn't crack open like it should. Try disconnecting your battery and reconnect to reindex the windows (follow instructions on cluster after reconnecting battery)
2016 1LT v6
- Totaled
Happiness: Infinite
Old 03-08-2024, 07:32 PM   #3
E75
Thanks for the reply! I gave up researching how to fix it myself and made an appt. at the dealer next week to drop it off. The car only has just under 1000 miles - hopefully they take care of it for free...
I don't think this is the issue though, because the window still goes down a half inch or so when I pull the door handle. And it goes back up to the position shown in the pic. Also, I noticed wind noise getting progressively worse over the last week or so. I was actually about to post asking how much wind noise is normal before I saw this...
On my old third-gen firebird, the door glass had multiple adjustments for every possible dimension. One of them controlled how far the glass "leaned in" so to speak or how hard it would press on the t-top seal when the door was closed with the window up. I'm hoping this 6th gen has some similar bolt that maybe they forgot to tighten enough at the factory. But even the black plastic triangle piece at the front of the window is cocked out a little away from the a-pillar seal.
Old 03-09-2024, 07:15 AM   #4
Deacon Blues
Drives: 2024 Camaro 1SS M6
Mine is *exactly* like this from the factory. I have to take mine in for warranty service when the snow stops falling here in WNY. Maybe we had the same person installing and indexing our windows from the factory
I picked mine up from out of state and honestly didn't notice, especially since the windows drop when you open/close the car doors (newest vehicle in our family, so never had anything that fancy). However, picked up on the wind noise driving, and after the first wash/detail, I noticed it was out of alignment. Hopefully it isn't a major fix, but I am definitely thinking it should be a warranty issue.
Deacon Blues is offline   Reply With Quote
Old 03-09-2024, 08:41 AM   #5
As you guys suspect, this is abnormal, the windows weren't installed correctly. They should lay flat against the seal and index up into the weatherstrip when the door is closed, with zero wind noise while driving. Hope y'all can get it fixed properly at the dealership.
Old 03-09-2024, 08:51 AM   #6
Deacon Blues
Thanks, glad that this isn't the norm. My plan is to have them fix it when I drop it off for the NYS inspection. Hopefully soon, I'm tired of seeing it in the garage with the cover on and not being able to drive it.
Old 03-09-2024, 04:05 PM   #7
E75
I was on the fence about trying to fix it myself, but decided if someone’s gonna break all the little clips behind the door panel I’d rather it be them so I can take it back later if it rattles…
Old 03-09-2024, 05:18 PM   #8
Deacon Blues
Can you please keep me posted on the warranty repair details, especially work order numbers? I'm about a month or give or take before I can get mine to the dealer, so if I can provide them with more details I would really appreciate it.
Old 04-11-2024, 10:17 AM   #9
keep_hope_alive
Electrical Engineer
keep_hope_alive's Avatar
Drives: 2023 1SS A10 Black
Any update? Keeping the responsibility on the Dealer is the right move here.
Daily Driver mileage update: 45k mi. @ Mar 2025
Old 08-08-2025, 07:59 PM   #10
Deacon Blues
Long time to revive but I just got my car back from the dealer for this warranty repair. Took 3 days to get it back, waiting on the part. They replaced the window gasket/seal on top of the door and reindexed the window. They also adjusted the door catches. Everything seems to be kosher, I'll know more when I give it a bubble bath tomorrow.
I was thankful that my dealer had a tech that only works on Corvettes and Camaros and the service manager was very forthright about the process. I didn't like leaving the car overnight, but it worked out.
I'd say if anyone else has this issue, make sure they have the part because we waited longer for that than the time to actually replace and adjust.
Old 08-08-2025, 08:39 PM   #11
Great resolution, happy to hear they helped you and your windows are now working as expected.
A dealership like this is solid gold, I'd give them a good survey result and make sure they know I appreciate their business as well.
Old 08-09-2025, 08:33 PM   #12
Deacon Blues
Indeed! I still do my own work whenever possible (just changed the oil this morning!) but for state inspections they have been great, so I felt good about bringing the car for warranty work in this case. They also had my wife's car in a few weeks ago for a remote start installation and the service manager took great care of us. Very thankful and will definitely give them a positive review when it pops.
Old 08-10-2025, 07:38 PM   #13
IMCWORTH
IMCWORTH's Avatar
Drives: 2023 Camaro Convertible ZL1 A10
First picture looks like your door isn't closed all the way!
IMCWORTH is offline   Reply With Quote
