![]() Drives: 2023 ZL1 1LE Join Date: May 2018
GIRODISC BRAKES...
My BC RS 45 should be here shortly. This set up should shave 20+lbs of un-sprung weight. I am looking at the Girodisc rotors that would shave another 20 pounds. 40LBS of un-sprung weight is a massive reduction.
My question is for the guys whop have actually replaced the factor rotors with this set up, did you notice any difference in handling on the car?
2023 BMW X4M Competition (Downpipes, Midpipes, Intake, Exhaust, Tune)
2023 ZL1 1LE BC Forged KXO5, 325/345 R888R, KPMF Satin Pearl Wrap, 2650/Heads/Cam/3200 stall/Meth- 918 rhwp/842 rwtq, Girodisc/Carbotech AX6, Race louvers. |
#2 | |
Moderator
![]() Drives: 18 ZLE, 18 SS1LE, 16 SS, 23 ZL1 Join Date: Jan 2021
I have the Girodisc rotors and I’m very happy with them. Reducing unsprung weight is always better than taking weight off elsewhere. Working on taking off even more with forged wheels and another brake upgrade soon.
#4 | |
Probably doesn't like you
Drives: 2022 WCT ZL1 M6 Join Date: Jun 2015
كافر ΜΟΛΩΝ ΛΑΒΕ железобетонное очко Quod gratis asseritur, gratis negatur. There is an unequal amount of good and bad in most things, the trick is to work out the ratio and act accordingly. |
![]() Drives: 2018 Cadillac CTS-V Join Date: Jul 2012
I went with the dba rotor rings, set of Ferodo pads for the street and hawk dtc70/60 pads for the track. Should arrive any day now. Girodisc was tempting as the quality is really good.
![]() Drives: 2021 1SS 1LE Join Date: Nov 2020
I've had Girodiscs on both my 1LEs and IMO, they are a significant upgrade. Lighter (can't really tell) better feel, even pad wear and more braking power. I've used both 3.12s and Cobalts and they have about the same performance, but I prefer the 3.12s. That said, the Cobalts are near half the price.
Ken
Follow my build - https://www.camaro6.com/forums/showthread.php?t=594295
#7 | |
Im not sure if there is a certain way you need to bed these when driving off the dealer lot, but the brakes feel TERRIBLE on this car. The brakes are very spongy, have a long pedal and very little initial bite. I will call KNS and go over an aggressive street pad selection with them.
#8 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2022 1SS 1LE A10 BCD WCT+PDR Join Date: Mar 2008
"KEEP THE FAITH"-Fbodfather |
#9 | |
![]() Drives: 2019 ZL1 1LE Join Date: Jul 2022
#10 | |
![]() ![]() Drives: Chevrolet Camaro ZL1 1LE Join Date: Oct 2021
#11 |
This might help some… folks over at KNS are pretty knowledgeable and helped me sort out the options and what would work best for me.
https://youtu.be/ZQLabUib5t4?si=IoZUigZZYjYxDFg_ |
#12 | |
