Old 02-29-2024, 10:59 AM   #1
Nallek
Drives: 2018 Camaro ZL1
Thoughts on upcoming mods - input requested
Hey all, I'm looking at doing the mods below to my 2018 ZL1. Let me know what you would change, what you think I'm missing, estimated HP gains, and if I'm just wildly wrong on something.
I know I'm missing shipping, tax, fluids, gaskets, bolts, etc. in this pricing
Nallek is offline   Reply With Quote
Old 02-29-2024, 12:14 PM   #2
Megahurtz
Snackbar Tuning
Megahurtz's Avatar
Drives: 2023 SGM ZL1
Low side fuel system...DSX Aux, KMS, In-tank etc.
GM Gen V Calibrator
Old 02-29-2024, 12:28 PM   #3
Nallek
with stock upper pulley, and moderate OD lower? I was planning on fueling later down the road, as its a hefty pricey jump.
Old 02-29-2024, 01:04 PM   #4
Megahurtz
Snackbar Tuning
Megahurtz's Avatar
If you plan to run Flex Fuel you will need a low side.
GM Gen V Calibrator
Old 02-29-2024, 03:36 PM   #5
Mikesvt04
Drives: ZL1 1LE
Looks like the same setup I'm go to run. I have a JMS voltage boost. They are like $400.
If you stay with the stock pulley and run a JMS booster u should be able to run e50+. I have a thread below yours asking the same thing lol.
Mikesvt04 is offline   Reply With Quote
Old 02-29-2024, 05:22 PM   #6
BunnyBoy
Drives: 2017 ZL1
I have headers, big gulp, JMS, flex fuel sensor, TB.... Im realizing that for very little money just for parts I could have a cam... Less the install and tuning.... I have everything else... Just need to install myself... NOT GOOD FOR MY WALLET.
BunnyBoy is offline   Reply With Quote
Old 02-29-2024, 06:32 PM   #7
CalgaryZL1
CalgaryZL1's Avatar
Drives: 2020 Chevy Camaro ZL1
200 shot! Even safe for babies, never mind the LT4
Old 02-29-2024, 08:19 PM   #8
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Ported blower and bigger TB will improve blower efficiency, especially if you spin the blower harder. That plus the fueling to run E are no brainers.
Old 03-02-2024, 06:07 AM   #9
dfxrte
Drives: 22 ZL1 M6
i had a similar mod list but instead just saving for a 2650 now
22 m6 zl1. cammed, headers, etc
https://ibb.co/qpWHXZM][img]https://i.ibb.co/NKm0Q46/zl1.jpg
dfxrte is offline   Reply With Quote
Old 03-02-2024, 07:57 AM   #10
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
X port, JMS, Headers, Rotofab, 103mm TB, E50. 680-700whp on stock pulleys.
Then if you want more, Port Injection and turn the boost up. I see no reason to tear these engines apart for a cam until you are trying to push past 800whp. These engines are plenty efficient as is to get up to that power. Just need efficiency mods and fuel supply to get there. Aside from that I like the BTR stage 1 better with the stock converter.
Old 03-02-2024, 08:29 AM   #11
mayracn
mayracn's Avatar
Drives: 2017 zl1
No one is installing a cam for that labor yet alone anthing else.
KOOKS LONG TUBES
AWE EXHAUST
ROTOFAB
FLEX FUEL 55% E TUNE
PORTED THROTTLE BODY
mayracn is offline   Reply With Quote
Old 03-02-2024, 11:44 AM   #12
sactownbwoy
Drives: '22 Camaro ZL1 1LE A10
Haha, that's what I did. But it's mostly for show since I compete in car shows.
sactownbwoy is offline   Reply With Quote
Old 03-02-2024, 11:59 AM   #13
Nallek
I wouldn't normally but I have a '18 (June 2018 build date), so I wanted to replace the oil pump and figured, well, we're already in there.
I wrenched my own work on my 5th gen when I owned it, and the headers weren't too bad on it, but looks significantly harder on the ZL1. Plus, I don't have enough hands-on experience to feel comfortable attempting the cam or oil pump myself, its a laborious job.
Old 03-02-2024, 12:01 PM   #14
Nallek
From what I've researched online, normal performance auto shop labor is ball park 90-150/hr. As for the amount of hours, I ballparked that based on other threads.
A friend of mine just got a quote not 24hrs ago to replace the cam bearings on her C7 stingray, and the labor was spot on with what I quoted above.
