02-25-2024, 08:07 PM | #1 |
Drives: 2015 SS Black/Black Join Date: Jun 2016
How much boost is to much?
I'm about to go in the shop for a clutch and I'm planning to turn it up while it's in there. ECS 1500 so should be around 12 pounds with the restrictor plate out and adding an aux pump to run e85. Anyone see any issues or concerns with turning it up? What boost levels do you all have on sbe? Or should I leave it at 8 pounds and just get the tune for e85 without turning it up?
2015 2SS M6 Stainless Power LT header w/ hf cats, NPP axle backs, ECS Novi 1500 SC, ATI 10% UD, BMR 1.25 springs, trailing arms, and bushings, short thow shifter, Z28 replica rims, BTR stage 2 centrifugal cam, zl1 pump, FIC 1000, and flex fuel
02-26-2024, 05:07 AM | #2 |
Drives: 2014 Camaro 2SS Join Date: Oct 2017
I'm at 10psi with my setup. I wouldn't feel safe going any higher than that on my STB. If I were you I'd just leave it and see how much power you pick up from E85.
But that's just my personal opinion. I know some guys run higher, but the risk just gets even more elevated. Who's tuning it?
Mods: GPI SS1 VVT cam, TSP long tube headers, LSA conversion, ZL1 fuel pump, ADM FPCM, DW 700cc injectors, Lingenfelter solid isolator, Dedicated Motorsports ZL1 reinforced brick, ADM Griptech 2.5 pulley, JLT CAI, Phastek intake scoop, NPP cat-back, GM 3.91 gears, Eaton Truetrac, Tuned by Chris @ CHenry Motorsports.
02-26-2024, 06:30 AM | #3 |
Planning on having Howard (Redline) tune it.
02-26-2024, 07:12 AM | #4 | |
Drives: 2010 Camaro Join Date: Dec 2022
My 2 cents? Go look at what a short block costs. If that that amount of money is acceptable to you, then turn it up. If the number upsets you, keep it at 8psi and on e85. I took my stuff apart after running 8lbs for a short time and found cracked cylinder walls and decided to rebuild then. Can't say if that was from me or age of engine. Some people have been able to beat on these engines all day and do incredible things while others such as myself found the limits very quickly. Just be prepared is all I'm saying. My friend is at 12? lbs with SC and e85. He seems to be doing fine for now.
2010 SS / 376 LSX / AGP Twin Turbo / 910whp 954wtq
02-26-2024, 07:20 AM | #5 |
Drives: 2010 Camaro SS Join Date: Dec 2006
I assume you have stock internals except for cam? I would think you will be getting pretty close to the limit if you push it to 12psi. It certainly could work with a great tune. How long is anyone’s guess. Things to look out for would be IAT’s. Temps do go up when you turn up the boost. Make sure your intercooler is up to the task at those levels.
The E85 will add a lot too. I still remain incredibly impressed with what E85 can do when I switch back and forth from 93 and E85. The timing you can pull off with E85 is a real game changer. And fun! Good luck! Let us know how it goes. |
02-26-2024, 11:17 PM | #6 |
Drives: 2014 Camaro SS 1Le Join Date: Feb 2016
Well speaking from experience, do it if you have money to spare for a new engine.If u dont, stay conservative. Mine went kaboom, and a new iron block/heads etc im here. Boost levels doesnt really matter. Doesnt matter who builds and tunes it, shit can go sideways real quick. Wrist pin/ rod or whatever can say "see ya later".
SEND IT!
2014 SS 1LE Money Pit/ Forged 402
CAM 22X/24X, .619/.617, 113 LSA/ LS9 Heads FIC 1200cc/DSX Aux Pump//McLeod RXT Clutch 730whp: 630Trq |
02-27-2024, 12:33 AM | #7 |
Good stuff. I've talked to him a few times. I'm actually planning on either doing a build there at his shop or just buy a zl1.
You should be in good hands though. Definitely let us know how it turns out!
02-27-2024, 04:21 PM | #8 |
Boosted Moderator
What is this expression “too much’…??? lol….
Send it… Provided you can comfortably afford a long block… I have a trail of broken parts down a certain racetrack… but I went butt wild on the boost… I did accomplish my goal, but I tore up some parts…
If the car feels like it is on rails, you are probably driving too slow. -Ross Bentley
Horsepower is how fast you hit the wall. Torque is how far you take the wall with you. “If everything seems under control, you're just not going fast enough.” Mario Andretti If you can turn, you ain't going fast enough... |
02-27-2024, 07:54 PM | #9 |
Thanks everyone for the advice, maybe I'll keep it at 8# and start planning for a drop in kit down the road.
02-27-2024, 07:56 PM | #10 |
No drop in kit btw. Gotta take that bad boy out, hone/balance etc. not like the lt1 platform on the vettes/6th gens.
02-28-2024, 03:48 PM | #11 | |
https://www.texas-speed.com/p-9331-t...ls3-crank.aspx
03-03-2024, 10:00 AM | #12 | |
03-04-2024, 05:40 PM | #13 |
J.Sick
Drives: 2010 Camaro SS Join Date: Nov 2010
I am at 715rwhp @10psi with an AGP twin turbo kit on E85. The tuner didn't want to go any higher for fear of popping the motor. For kill mode I run 14psi not often but it does happen. I have been at the HP for 8 years stock motor. Been thinking about a cam now.
"J.Sick"
2010 Camaro 2SS |
03-05-2024, 02:07 AM | #14 |
Drives: T Join Date: Mar 2015
my 5th gen is still kickin
pump gas ca 91 500 whp @ 7-8lb's 76mm turbo i dont know how many years its been but this car was setup and tuned when the huron single turbo first came out. im going to btr stage 2 turbo cam, go e85 and get a looser converter. i "think" it will do 600-620 whp at the same psi with a cam and ethanol. just a fun street car on rims. |
