Old 02-25-2024, 10:51 AM   #1
JSH
JSH's Avatar
Drives: '20 ZLE
Manifold Pressure Drop
We're in the tuning process, the car runs well, and the most surprising data we've seen so far is a drop in absolute manifold and boost pressure from 31# in the previous build to 25# in this build.
The previous build was OEM shortblock with LME heads designed for the Hennessey 850. The new build has LME's short block and race heads.
Kong has always said that 31# was too high and that I needed a more efficient motor.
Has anyone else here seen such a drop?
2020 ZL1LE A10.
100 octane: 1045hp/1055tq.
Old 02-25-2024, 01:31 PM   #2
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
We're in the tuning process, the car runs well, and the most surprising data we've seen so far is a drop in absolute manifold pressure from 31# in the previous build to 25# in this build.
Yeah huge drop when I went with the Mast heads and new cam vs the stock longblock. Had to make a major pulley change and spin the blower a lot harder since the motor could move a lot more air. Sounds like you’re on the right track!
Old 02-25-2024, 02:12 PM   #3
JSH
JSH's Avatar
Drives: '20 ZLE
I was using a 2.625 upper previously but put a 3" on it to start with. Sounds like I should go back to 2.625
2020 ZL1LE A10.
Old 02-25-2024, 03:00 PM   #4
Joshinator99
Moderator
For sure, that still might not be enough but it’s a logical next-step.
Old 02-25-2024, 04:10 PM   #5
JSH
JSH's Avatar
Drives: '20 ZLE
Shouldn't I expect the boost to go down a little bit as my tune gets better and more efficient? This has changed my thinking about boost.
2020 ZL1LE A10.
Old 02-25-2024, 07:51 PM   #6
Joshinator99
Moderator
Nothing to do with your tune.
Boost is a measure of restriction. Letting the engine move air more easily means the blower puts the air into the motor with less “boost”. This lets the blower operate at a different point in its compressor map…so less boost doesn’t mean less airflow…it just gets into AND out of the engine more easily. You can tell by your MAF values how much air you’re moving so just adjust your blower speed accordingly. If you’re trying to max out a PD blower, you can’t be trying to run 30-35 pounds of boost (unless the blower is specifically designed for that like some turbos are)… you needed more airflow but lower boost…say 22-24 pounds max.
Old 02-25-2024, 10:07 PM   #7
JSH
JSH's Avatar
Drives: '20 ZLE
When you say boost, you mean total manifold pressure (ambient + boost)?
2020 ZL1LE A10.
Old 02-26-2024, 07:06 AM   #8
Joshinator99
Moderator
Yes. Boost is just the differential between manifold and atmospheric pressures.
Old 02-26-2024, 10:20 AM   #9
ZL1Atlanta
ZL1Atlanta's Avatar
Drives: 2017 Chevrolet Camaro ZL1
My last engine was a 416 ci with LME's max effort CID heads and made 29.5 psi. On the new engine (427 ci) using the same pulley combo it made 21.5 psi. The lower the better with a 2650.
2017 ZL1 - PB 7.85 @ 175 MPH @ 3682 lbs @ 1313 DA (work in progress)
Built by Vengeance Racing, tuned by Elite Tuned
ZL1Atlanta is offline   Reply With Quote
Old 02-26-2024, 10:57 AM   #10
JSH
JSH's Avatar
Drives: '20 ZLE
This has changed how I think of boost. Kong had told me all along that I needed an engine that would flow more air to take full advantage of the 2650. I was thinking that more spark advance would consume more air.
2020 ZL1LE A10.
Old 02-26-2024, 01:12 PM   #11
ZL1Atlanta
ZL1Atlanta's Avatar
Yep, keeping boost down has been a major focus on this build. TooHighPSI explained the importance early on with the 2650 and it definitely seems to have paid off.
Old 02-26-2024, 02:49 PM   #12
2018ZL1
2018ZL1's Avatar
Drives: 2018 ZL1 A10 NFG 2019 COPO 350 SC
My stock LT4 engine made 21lbs of boost and when we installed the new bullet it made 15lbs! Pully'd up to get to 17lbs.
2019 COPO #32
350 SC
8.25 167MPH
2018 ZL1-NFG-A10
388CI L8T
9.32 147MPH
2018ZL1 is offline   Reply With Quote
Old 02-26-2024, 03:34 PM   #13
jlaudio11
jlaudio11's Avatar
Drives: Chevy Camaro
Like others have stated, boost a measurement of resistance. A bigger engine, moving more air is going to have less resistance. Look at airflow or hp numbers if you want to compare apples to apples. It could also make a little less boost as the tune is dialed in and the engine is running more efficient.
'20 Camaro LT1
Twin 67/62 turbo 401(L8t) Texas speed forged piston & rod, BTR stg1 turbo cam, holley ultra lo, port injection, circle d 3600 stall, et street r’s on racestar recluse wheels.
1.33 3.75 5.75@122.98 1/8 pb 9.04@141 1/4 pb technically
'94 Camaro Z28 6mt cc306 cam, 4:10's, longtubes with x pipe, otr intake
jlaudio11 is offline   Reply With Quote
Old 02-26-2024, 05:56 PM   #14
Joshinator99
Moderator
