Old 02-24-2024, 07:29 PM   #1
K6.2B
Drives: 16’ Camaro 1SS
Normal or not normal?
Good afternoon everybody, just noticed some intermittent “clicks” while walking up to the car and was wondering if this sounds normal? Mods are 95mm TB, lt2 IM, 2” headers, exhaust, and e85. No codes or weird driving from car. Any insight would be appreciated!
http://https://youtube.com/shorts/1kPPDkxawxA?si=PpQ3R1VnfLZgDS42
K6.2B is offline   Reply With Quote
Old 02-24-2024, 10:33 PM   #2
NiickySaz
NiickySaz's Avatar
Drives: 2023 Camaro 1LT V6
Butterfly valves in muffler(MRBP?) normal wear an tear?
NiickySaz is offline   Reply With Quote
Old 02-24-2024, 11:28 PM   #3
K6.2B
Hey niicky thanks for the response. the exhaust has no mufflers nor valves. I would like to think it’s wear and tear but I’ve watched a few videos on YT on cars with similar problems (not Camaros) and most of them lead to a bad coil pack, injector, or both. So I’ll try that I guess. If it was a misfire it would throw a code right?
Old 02-25-2024, 08:18 AM   #4
WhiteMale
Drives: 23 ZL1 A10 Rapid Blue
Under the hood or just at the tailpipes? A misfire can flash the CEL but may not throw a code IIRC.
Old 02-25-2024, 08:54 AM   #5
K6.2B
Good morning White, as far as I know it’s only at the tail pipes. All the other ticking noises I heard from under the hood sound like every other DI camaro but I will post a vid when I can. No flashing or steady CEL whatsoever. Appreciate the input.
Old 02-25-2024, 10:30 AM   #6
Dynamical
Dynamical's Avatar
Drives: 2022 Camaro LT1 A10
Manual or AUTO? If auto, what did you do for the AFM valves? That clicking reminds me of something similar to an electrical switch which isn't working correctly.
Or do you have cats? Is it possible a piece has broken loose and tapping around on the inside?
2022 Camaro LT1 A10 - Drag Pack/Corsa double X pipe/AWE track axleback -11.849@118.67MPH/1.798 60'
2001 Camaro SS A4 - HCI/Stall/Bolt-on/Gear/Tune/DR/Diet - 429HP/392TQ - 10.99@123.58MPH/1.584 60'
1998 Camaro Z28 A4 - Bolt-on
1999 Camaro Z28 A4 - Stock
Dynamical is offline   Reply With Quote
Old 02-25-2024, 11:34 AM   #7
K6.2B
What’s up dynamical, thanks for the response. the car is a manual 6-speed with no cats. I’m currently checking torque values on the exhaust & intake manifold and all is to spec.
Old 02-25-2024, 04:00 PM   #8
NiickySaz
NiickySaz's Avatar
This is what I meant, AFM valves 🤦🏻*♂️
Old 02-26-2024, 10:56 AM   #9
Katech_Mike
Drives: 2015 Camaro ZL1
Exhaust valves are going bad. Extremely common.
Katech_Mike is offline   Reply With Quote
Old 02-26-2024, 11:02 AM   #10
WhiteMale
If it's the exhaust valves and you're interested I can sell you the valve's off of my ZL1 muffler.
Old 02-26-2024, 05:55 PM   #11
Dynamical
Dynamical's Avatar
He said he has no valves though! Lol
Old 02-27-2024, 10:23 AM   #12
Spudsmaro
Drives: 2021 LT1 6 SPEED MANUAL CAMARO
Mines has the exact same mods, and does the exact same thing. Also am a 6 speed as well. Either it’s normal or it’s “knock” but usually with “knock” you get small puffs of white smoke out the tail pipe (what I’ve heard from some tuners, could be false). However the car runs amazing and no drivability issues other then me not using my clutch correctly 🤣🤣
Spudsmaro is offline   Reply With Quote
Old 02-27-2024, 03:25 PM   #13
K6.2B
Originally Posted by Spudsmaro View Post
Mines has the exact same mods, and does the exact same thing. Also am a 6 speed as well. Either it’s normal or it’s “knock” but usually with “knock” you get small puffs of white smoke out the tail pipe (what I’ve heard from some tuners, could be false). However the car runs amazing and no drivability issues other then me not using my clutch correctly ����
No valves in the exhaust guys. Yeah mine drives great as well, it was just at idle when I noticed the pops. I was under the impression it was a misfire but whatever it was it’s gone. Took it apart down to the injectors and bolted everything back up. I’m thinking maybe something was loose (bolt or bolts) or an electrical connector not properly seated oh well ‘til the next issue! Haha appreciate all the input.
