Speaker tap 2023 1SS vert.
Hi!
I have a Kicker HS8 powered sub i ran in another car that was totally satisfactory for my needs. I need to tap into the rear speakers on my 1SS convertible. I know that i can pull the sail panels in the rear for speaker access but need to tap there and run to the trunk for the amp. The amp needs speaker input from both sides, a hot, and ground. Obviously hot and ground are in the trunk. I was looking but of course the top doesnt want to stay in the half open position. Anyone have any insight as to where to tap in or where the best place to run wires is? Or , can i disconnect the battery while the top is half open so it stays there? thanks!
2012 THR45 SS - CFM - SOLD
2015 2SS 1LE - White - SOLD 2002 Corvette coupe - 6M - Millenium yellow - SOLD 2010 2SS RS - RJM - 6M - SOLD |
![]() Drives: 2017 ZL1 Vert M6 Join Date: Feb 2019
This MIGHT help with your question about keeping the top open:
https://www.camaro6.com/forums/showthread.php?t=480519 |
![]() ![]() ![]() ![]() ![]() Drives: Chevrolet SS 1LE Join Date: Oct 2019
You don't want to tap into the rear speaker signals for your sub: they aren't full frequency range. You want to tap into the front speaker signal.
Matt Miller
2020 SS 1LE |
Bose or non-Bose?
https://lljcustoms.com/products/2019...fier-t-harness https://t-harness.com/products/2013-...-t-harness-r2g Last edited by Plasar; 02-29-2024 at 05:00 PM. |
#5 | |
Electrical Engineer
If it's non-Bose, you can access the speaker wires at the passenger side dash or at the dash speaker location. If it's Bose (meaning you have the technology package), then you'll want to intercept at the factory sub output. Assuming it's non-Bose, I have all of the 1SS audio schematics. Attached are with and without active noise cancelling, non-Bose.
1100: 5/3/22 . . . . . . . 2000: 6/25/22 . . . . . .4000: 8/17/22 . . . . . . . 6000: 9/10/22 Daily Driver mileage update: 45k mi. @ Mar 2025 New Engine @ 22,600 mi. due to dealer confusing bad gas with a bad engine. Build Log: https://www.camaro6.com/forums/showt...6#post11353116 |
Dean and Fernando at Five Star Car Audio agree with Msquared and Keep_hope_alive.
https://youtu.be/xqsvpggwfyE?si=LJ84yocRNzKxctpr |
#7 |
![]() ![]() ![]() Drives: 2019 zl1 6 speed Join Date: Jul 2017
Don't forget to cut your active noise canceling wire!
#8 |
Electrical Engineer
Attached are a collection of ANC schematics, pin-out diagrams, and the system description.
Disconnecting the microphones is the easiest solution that doesn't require cutting wiring, and there are two mics. How the system integrates depends on the trim level/audio system you have.
#9 | |
Matt Miller
2020 SS 1LE |
#10 |
Electrical Engineer
I also intercepted my wiring with a breakout harness:
#11 |
Thanks all! I am digging back into the project.
#12 |
does anyone have any insight about how to get into the trunk though....the convertible top in the way is still a thing.
#13 |
![]() Drives: 2024 Chevrolet Camaro 1SS coupe Join Date: Dec 2023
Hi guys, I'm new to this forum and looking to upgrade my 2024 1SS stock unit. It seems that Gen5DIY T-harness is sold-out for a while. I've seen other suppliers with similar T-harness, does anybody have tried another ? Don't want to cheap out but they seem cheaper too...
#14 | |
Matt Miller
2020 SS 1LE |
