![]() Drives: 2016 Chevrolet Camaro, 3.6L Join Date: Feb 2024
Elect Grems after trunk water / Voltmeter 9
Replaced rear fusebox after trunk water damaged it. Replaced alternator due to no charging (same water event). Car runs and starts mostly fine
Battery shows 12.5V car-turned off, and 14.4V when on and charging. However, voltmeter on panel pegged at 9 regardless. Charging system service message. Grems include: no light in shift handle display, windows roll down not up, first push on start button no response, second push ACC mode, then third push it starts, interior trim lights don't work. Dealer says: "Found an open in the body harness to the bcm causing the BCM to read battery voltage as 35.3V recommend replacing body harness Additional parts and labor may be required. Parts: Body harness Coolant Refrigerant 1.2 R134a $5,056.14" Also says harness is unavailable for order which is inconsistent with above recommendation. SO, 5 grand is a non-starter even if I COULD get a harness. Going to go pick up car and trouble shoot more. Thoughts 1. If accept open-circuit wire, could I just add a jumper wire? (I'll have to get into diagram to see if anything taps into it along the way)(they will have to ID the wire for me) 2. If I don't accept analysis, thinking this: - what/where is source of voltage signal? - could a bad AGM battery be causing this? replaced 6months ago Autozone and they test it good now. Has run dead a few times due to different issue. - bad grounds? - bad BCM? ECM? 3. If BCM thinks 35.5V, wouldn't it disengage alternator so that I would not see 14.4v when running and batt eventually go dead? Wouldn't the voltmeter peg high rather than low? or is this just an indication of an invalid signal? Anyway, REALLY would like to avoid 5grand to start with - prob will end up more... and this is after a 4grand tranny rebuild due to the dreaded torque-converter shudder ... sheesh! (shoulda bought that corolla .. lol!) Any insights and ideas to get me started on troubleshooting greatly appreciated. 2016 2LT 120k miles ***Update 1*** Dealer rescinds estimate due to harness not order-able/out of production. Asks if wants tech to run the wire for $200/hr and how much do I want to dedicate to the goose-chase. I am not liking my odds... prob take it home and poke at it a while longer. ***Update 2*** Discussed with tech. He ran a jumper to confirm the open-circuit wire he found - it solved the only two codes listed and that relate to charging system. Windows, although they have power, will still not roll-up, interior light trim still no workie, three press to start, no light in shifter. Says to run a permanent jumper prob 5-6 hrs@$200/hr to solve that one issue so $1000+. The other issues are still a mystery, but agreed that they are tied into BCM, so BCM replacement $220part/$200 labor. SO, having them do the BCM, and then I'll run the jumper at home. Hoping that solves all issues. If not, perhaps I"ll discover other wire issues when running jumper.. Last edited by flynscott; 02-26-2024 at 02:45 PM. |
#2 | |
I do not understand how an OPEN circuit would cause a module to overreport voltage. Since you probably paid for dealer diagnostics, I would try to get the specifics of what they diagnosed. It does sound like you are getting an active charging cycle if you are reading 14.4 V at the battery. I have posted other threads with lots of details on the power management. I am pretty certain a BCM reports battery voltage to the ECM and there is one wire from the ECM that controls the alternator duty cycle. I think the controls go 0-100% in 10% steps. So your digital meter reading 14.4 V charging may not exactly mean CONSTANT 14.4 V. it could read that at 80% duty cycle depending on the meter. Not such a big deal, as it's great to know it IS charging. What is with the AC recharge? I'll assume that's unrelated to the water damage or dealer trying to upsell some service. |
![]() ![]() ![]() ![]() ![]() Drives: 2020 Chevy Camaro ZL1 Join Date: Apr 2023
This is a long shot but do you have after market led side markers? If so when the harness gets moisture/water in it, it can cause havoc. If you haven’t changed side markers, disregard comment.
ctrlz,
Yeah, the 35V doesn't make intuitive sense. If the circuit is open or broken, I would expect 0V. Or possibly the BCM invalidates the signal and chooses a default - but still, 35V as a default? I am also suspicious of his contact point to measure resistance in that wire - poor contact point = infinity resistance (open). I'm also interested in the source for the voltmeter and/or wire to the BCM. So far they have stiff-armed getting the tech on the phone so going in person in a couple days. AC recharge? No idea. Perhaps have to open AC system to get at harness?? |
Calgary,
The only aftermarket component is a sub-woofer amp also in trunk that had about 2-3 inches of water. Will disconnect the amp once I have car back - cuz, why not. I have read that add-ons can cause some strange effects in this beast. |
If you are literal about 2 to 3 inches in the trunk, good luck brother. That’s a can of whoop ass.
#7 | |
Side note: after draining, rained overnight and then froze. Ended up with another inch of ice in trunk we had to thaw and drain before starting work. Doh! |
#8 |
***Update 1***
Dealer rescinds estimate due to harness not order-able/out of production. Asks if wants tech to run the wire for $200/hr and how much do I want to dedicate to the goose-chase. I am not liking my odds... prob take it home and poke at it a while longer. ***Update 2*** Discussed with tech. He ran a jumper to confirm the open-circuit wire he found - it solved the only two codes listed and that relate to charging system. Windows, although they have power, will still not roll-up, interior light trim still no workie, three press to start, no light in shifter. Says to run a permanent jumper prob 5-6 hrs@$200/hr to solve that one issue so $1000+. The other issues are still a mystery, but agreed that they are tied into BCM, so BCM replacement $220part/$200 labor. SO, having them do the BCM, and then I'll run the jumper at home. Hoping that solves all issues. If not, perhaps I"ll discover other wire issues when running jumper.. |
#9 |
If you have parts with the original stickers, you might be able to find junkyard pulls on ebay.
#10 |
Update 3
***Update 3***
Took car to an alternate dealer. Diagnostic result was that there is some corrosion on harness connector and alternator output is low. Their solution (regulated and restricted by Chevy documentation), is to replace wire harness and alternator. I have already replaced the alternator. The problem is that the wiring harness is no longer being built for this car (2016!). So they punted. Recommended to take to an independent shop. Made appointment to the one they recommended, who called back and punted as well - they don't want the job. Meanwhile, thought I would do the easy part and replace the replacement alternator. And like magic! It fixed ALL known problems!! Car now charging and all anomalies were corrected! AAaaaand ... the buzz-kill. Went out to start it today - and all problems returned. Took two pushes to start, voltmeter pegged at bottom "9volts", "Service Battery Charging System", interior lights not working, and I presume windows won't roll up (didn't test this because I don't want them stuck down. Next up: will try to schedule another shop. While I wait, might message with grounds and alternator plug, see if I can clean up any corrosion I can find. Any other ideas? |
#11 |
![]() Drives: 2024 Camaro 1SS Join Date: Mar 2024
Early in your posts you stated you have an aftermarket battery. Replace it with a stock.
#12 | |
Below is latest update - hopefully will persist and stay good - if not, splice harness leads and battery would be next |
#13 |
*** Update 4*** (final ?)
SO. Thought to go verify grounds - noticed that through our neg battery cable off and on again throughout this odyssey, I had left it only partially on/secure. Replaced it tightly and also attached batt cable to ground and to a large bolt on underside. Cranked up, aaaaannnd .... everything back to normal! Removed cable - still normal! So, back to original thought - the replacement of the replacement alternator solved the gremlins. It IS still possible that is is momentary due to an intermittent connection or weird battery logic - so will put some miles and cycles on it before claiming victory again. If no change, will call this a "WIN". If fortunes change, will let you all know. Thanks for all of your inputs and suggestions! Scott |
#14 |
Last update and solution: Prob came back. However, and I don't remember why I was doing this, but with son in car and key on I began wiggling wires at the fuse box connectors. Son says "Hey! Ligths are back on!" So repeated the wiggling and narrowed down a wire. Yup - wiggling turns lights on/off. Replaced connector and voila - all lights work, windows, radio etc. Prob solved. Hopefully we are done with the post flood elect issues.
| Tags |
| 9volt, charging, electrical, gremlins, voltmeter |
