#1 | |
Drives: 2021 ZLE, C5 Z06 6.0L Procharged Join Date: Mar 2023
I wanted to share something that has happened to my ZLE and has caused quite a bit of frustration tracking down the origin of oil vapor smoke from under the hood while driving the car. If you track or street drive your Camaro, it might be worth your time to check the aux cooler in front of the radiator for tiny stones/rocks getting caught between the cooler and the plastic mount holding it in place. Mine has two pin-holes that only come into play when the transmission temps exceed the 190-degree thermostat and begin to flow at higher pressures. This is why it was so hard to find, as driving easy on the highway, my trans temps never reach this temp, thus the oil leaking was intermittent to show up.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2022 1SS 1LE A10 BCD WCT+PDR Join Date: Mar 2008
Great find. Having owned a Gen5 SS 1LE and now a Gen6 SS 1LE, I've made it a point of maintenance to clean all the junk that builds up below and around the radiator/aux coolers.
Two things I noticed in your description of the fluid flow path. The line that runs up the passenger side from the diff, according to a parts diagram that I pulled from a '23 A10 ZLE, it connects to the passenger side of the horizontal aux trans cooler(#16 in the below pic), not the upper radiator port. This duplicates the diagram of my A10 equipped SS 1LE. Also, the fluid path may be reversed. I base this on a few documents of noted fluid flow and my own experience. Long story short, even to this day with my own findings during my ATF fluid change procedure, I have my doubts with what I have observed are correct, and this would point to you being correct. While the documents may be wrong, they do almost seem counterintuitive. It is possible I have missed something in this understanding because I have not confirmed myself which trans port at the thermostat/bypass block daylights fluid back into the pan. In the second pic, it looks like cool fluid travels down the passenger side first, to the diff, picks up heat, then travels down the driver's side. If this is the case, yeah, it is odd. I would think getting the coolest fluid to the trans would be priority #1. The last pic is from Improved Racing's GM trans thermostat adapter instructions. It shows the rearward port is the outlet port, sending fluid to the cooler first, which fluid would then go to the diff and finally back to the trans. Trans fluid flow pat starting from: the pickup in the sump thru trans circuits/converter out to coolers to diff back to trans ?? https://www.improvedracing.com/6l-8l...hermostat.html #fjb
"KEEP THE FAITH"-Fbodfather |
Petro-sexual
What was the part number you used for the tranny cooler?
| Tags |
| 1le, a10, leaks, zl1, zle |
