Old 02-17-2024, 09:43 PM   #1
Ronin zl1
Drives: Chevy Camaro
Unhappy trunk flooded on my zl1
hello, I finally was able to purchase my dream car a zl1, not 2 weeks pass were it started to rain and my trunk flooded here in LA
there was about an inch of water in the trunk. I was able to clear out the water and dry all the components however my screen does not turn on nor can I hear any sound. my back up camera works when I put it in reverse but that's about it. is there anyone here that fixed the issue without having to take it to the dealership? if so the help would be appreciated.
thank you.
Ronin zl1 is offline   Reply With Quote
Old 02-17-2024, 10:07 PM   #2
Dirtbike
Drives: Chevrolet Camaro
Ouch - I may not be much help here, but your battery and important fuse box is right there in the trunk. Along with several other modules. I suppose best case, one or more of your fuses popped and saved some or all of it. If so, I'd make sure it's all bone dry before trying new fuses (if they are blown). If the fuses aren't, I'm afraid you may have bigger problems.
Check your fuses and cross your fingers.
Dirtbike is offline   Reply With Quote
Old 02-17-2024, 10:41 PM   #3
Ronin zl1
its funny that every thing on this image works fine its just the screen and the radio.
smh I may just have to take it to the dealership.
thanks for the reply dirt bike I appreciate it
Old 02-18-2024, 08:51 AM   #4
ctrlz
thank you.
Search for threads by lynyrd. He's got a series on resolving this nightmare.
https://www.camaro6.com/forums/showthread.php?t=611576
Old 02-18-2024, 11:41 AM   #5
The Maverick
Somewhere in the Kalahari
The Maverick's Avatar
Also, this thread shows how he relocated components from the trunk floor to help prevent a recurrence:
https://www.camaro6.com/forums/showthread.php?t=613210
Old 02-18-2024, 01:21 PM   #6
KC64
Gray Ghost
KC64's Avatar
Drives: 24 Camaro 2SS Loaded
If this is a new car it should go right back to the dealer.
KC64 is offline   Reply With Quote
Old 02-18-2024, 03:15 PM   #7
SomeGeoffGuy
SomeGeoffGuy's Avatar
Drives: 2023 2SS Convertible
Yes - times 100! I would think this is all warranty. That trunk is supposed to be sealed for rain. That is BS.
-Geoff
'16 2SS Convertible - White on white, mag-ride, NPP, nav. Sold!
'23 2SS Convertible -Same as above except orange.
SomeGeoffGuy is offline   Reply With Quote
Old 02-18-2024, 03:35 PM   #8
CalgaryZL1
CalgaryZL1's Avatar
Drives: 2020 Chevy Camaro ZL1
Damn! I wonder what the cause is for some and not others? I wonder if I should install a bilge pump.
Old 02-18-2024, 05:25 PM   #9
L2SS455
L2SS455's Avatar
Drives: VOM 2022 2SS
WTF, I've wash the Camaro (22 VOM 2SS)by hand with tons of water on the rear including the under carriage many times. Never noticed any yet. That's not supposed to happen. At least not like my first new car in 1976 a Cougar XR7 that leaked from the top back window. Take it back ASAP if new and have them fix it under warranty.
L2SS455 is offline   Reply With Quote
Old 02-18-2024, 05:32 PM   #10
302crossram
302crossram's Avatar
Drives: 2023 Sharkskin 2SS
what year ?
Old 02-18-2024, 05:33 PM   #11
302crossram
Old 02-18-2024, 08:08 PM   #12
Number 3
Hail to the King baby!
Number 3's Avatar
Yes, you may not like your dealership and you may want to do it yourself but taking it to the dealer protects you against any down stream issues from the leak.
Worst story ever was a Cadillac Eldorado owner had a flat tire in the winter. Went to get the spare and it was under ice from a water leak that froze.
If it’s under warranty take it to the dealer.
Old 02-19-2024, 06:40 AM   #13
sklippi2018
Drives: 2021 ZL1 A10
Man that stinks. Like most have said if it is under warranty take it to the dealership to fix and to avoid any hassle(s) if it comes up again.
And, this thread jogged my memory. A few months ago I saw this vid from Hot 1LE that talked about this issue. May be minor but hope it helps.
sklippi2018 is offline   Reply With Quote
Old 02-21-2024, 10:33 AM   #14
The Maverick
Here is a link to a service bulletin on the issue of water in the trunk: https://static.nhtsa.gov/odi/tsbs/20...81677-9999.pdf
It specifies other possible causes for the issue beyond the two mentioned in the video:
Last edited by The Maverick; 02-21-2024 at 10:49 PM. Reason: Fixed link, thanks to Whoomba!
