Old 02-08-2024, 04:14 PM   #1
Whoomba
Am I being anal about the splitter?
I’ve got less that 500 miles and it already got road gunk stuck between the splitter and the bumper which of course is pitting the bumper. I’ve never had a splitter before so I didn’t think about this being an issue. I had a white one before and the road rash was a bummer. I’m thinking of taking the splitter off except for special occasions and getting a clear bra. I know I can count on you guys giving me you’re opinions.
Old 02-08-2024, 05:19 PM   #2
JT6Speed
JT6Speed's Avatar
Drives: 2023 Camaro 1SS M6
If it's the 1LE splitter like I have, it's not really something that can be taken on and off easily. There's a good deal of 3M tape if I'm not mistaken.
It depends what you want to do, but I think it makes the look of the car. I haven't driven in any excessively dirty conditions, but in the last year and a half it has stayed pretty clean, nothing a good wash can't remedy.
Black 2023 Camaro 1SS Coupe M6
Ordered: April 2022-----Built: July 2022-----Delivered: September 2022
-Dual-Mode Exhaust (NPP)
-Red Painted Calipers (J6F)
-5 Split Spoke Bright Silver Painted Aluminum Wheels (56W)
-Chrome Camaro Logo Fender Badge
-Second Generation Front Splitter in Satin Black
JT6Speed is offline   Reply With Quote
Old 02-08-2024, 05:39 PM   #3
22SS1LE
Drives: 2022 1SS 1LE 6M
I dont know where you drive. I havnt had any issues in 3300miles so far. Nothing has yet to get stuck between it and the bumper.
You are not getting that splitter off. It is taped, bolted and riveted in and very hard to remove. Its not something that can be taken off and the car look ok. there will be holes all over
2022 1SS 1LE 6M in Riverside blue
Found exact build local- ETA 7/31/22
New ETA - 7/26, 7/30, 7/31, 8/1, 8/8, 8/15, 8/21, 8/28, 9/17
8/24. IT HAS ARRIVED at the dealer
8/25- It is in the Garage
ACS ZL1 Sideskirts, 20% tint, CAI Intake
22SS1LE is offline   Reply With Quote
Old 02-08-2024, 05:46 PM   #4
Curr
Probably doesn't like you
Curr's Avatar
Drives: 2022 WCT ZL1 M6
I wouldn't worry about it unless you're going to be exhibiting the car on a concourse or something for ribbons, or saving it for the next guy.
It's nice to prolong it being "as nice as possible" for as long as possible, but don't let it detract from enjoying as much as possible.
I vote: Just drive it
كافر
ΜΟΛΩΝ ΛΑΒΕ
железобетонное очко
Quod gratis asseritur, gratis negatur.
There is an unequal amount of good and bad in most things, the trick is to work out the ratio and act accordingly.
Curr is offline   Reply With Quote
Old 02-08-2024, 05:56 PM   #5
Corky
Corky's Avatar
Drives: 2019 1SS M6
When I added the GM ground effects the PPF went on the next day....
1st Gen ground effects kit GBA black | Mamo V3 ported TB | GM CAI | Velossa Ram Air | AWE touring axle back| Xpel PPF | illuminated door sills | Upgraded door panels with spectrum lighting |ZZP pillar pod with Banks Idash pro/AEM wideband
Corky is offline   Reply With Quote
Old 02-08-2024, 07:33 PM   #6
Don't take that splitter off, that's a very bad idea. PPF is the way to go, and if anything lodges between the splitter and the bumper (you should have a layer of tape between them, by the way), you blow it out with the power washer. I definitely wouldn't sweat this.
One thing you might want to do, though, is to protect the bottom of the spliiter with something like this: https://www.amazon.com/gp/product/B09KZHFR99. It saved mine a few times already on bumpy roads and in the occasional steep parking lot/driveway situation.
Old 02-08-2024, 07:58 PM   #7
Whoomba
Thanks guys. As a follow up, it’s a 2SS CE, I’m thinking now there won’t be a next guy for a long time. There were several pieces of grit stuck between the splitter and the bumper I had to pry out with a razor knife. I want my cake and eat too. I want to drive it but I’d love to keep it as pristine as possible.
Old 02-08-2024, 08:54 PM   #8
speedyink1
speedyink1's Avatar
Drives: 2023 Camaro 1SS 1LE 6MT
I don't think I have crap stuck in mine after 3800km. Are you talking in the wheel well or something, or actually in the front of the car?
I suppose I do drive very carefully, leaving room between the car in front of me, and avoiding where rocks build up on the road so I don't have to hear shit hitting the wheel wells.
speedyink1 is offline   Reply With Quote
Old 02-08-2024, 10:47 PM   #9
DEADBYDAWN
DEADBYDAWN's Avatar
Drives: Chevy Camaro 98Z
I was going to get a spitter but decided it looks fine without it.
DEADBYDAWN is offline   Reply With Quote
Old 02-09-2024, 10:52 AM   #10
Whoomba
Under the headlight and in the middle.
Old 02-09-2024, 11:05 AM   #11
ctrlz
I had my splitter off to replace it. The stock splitter is held on with double-sided tape and rivets. You need to drill out the rivets to remove. I followed GlenA's advice and used braided fishing line to "saw" through the adhesive tape. also following Glen's advice, I used plastic push rivets to install the new one, minus the tape. The idea being you can remove it more easily for cleaning later on. Never had it off since.
I had cracked the splitter, and once I had it off, I wished I had saved all the bits. It is all ABS. A bit brittle, but that plastic responds well to solvent adhesives. Sand it up and repaint and I'd have a nice spare.
Old 02-11-2024, 12:22 AM   #12
DEADBYDAWN
DEADBYDAWN's Avatar
Don’t blame you. Maybe try the fishing line technique to remove anything that gets lodged in there. Some stren 10lb test. I used it to take off the lame badges on my 98 z28 and installed 69 z28 badges.
I am guessing you already tried hitting it with a pressure washer.
Old 02-11-2024, 10:41 AM   #13
SamSmoothCastel
Drives: 67 Orange Mustang Coupe
PPF will be your splitters best friend
SamSmoothCastel is offline   Reply With Quote
Old 02-11-2024, 11:36 AM   #14
cdrptrks
cdrptrks's Avatar
It will likely take you over an hour just to scrape off all of the adhesive foam tape residue after you have the splitter off. I used a plastic razor blade and a lot of Mothers R3 spray but there might be a better spray to use. There were 4 rivets to drill out on my 2017 and those holes are visible with the splitter removed.
I used 20 lb test fishing line with gloves so it didn't dig into my hands. It broke about 10 times during the sawing process. I also used a snap blade utility knife to cut some of the foam while pulling the edges of the splitter away from the car so the metal didn't scratch the paint.
