Old 02-06-2024, 04:26 PM   #1
Gr3m27
Drives: Camaro
Whipple Camaro ZL1 Hood Insert
Is anyone using the Whipple Camaro ZL1 Hood Insert for the new 3.0 Whipple?
If you are can you share some pictures of it on the car?
2017 Chevy Camaro Krypton Green ZL1
Gr3m27 is offline   Reply With Quote
Old 02-06-2024, 04:28 PM   #2
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
'20 ZL1 Black "Fury"
Old 02-06-2024, 05:52 PM   #3
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Agreed, I haven’t heard of this. I’m running the small subframe spacers that Whipple provided and it clears the stock SS hood. I believe the ZL1 hood has even more clearance already too.
Old 02-06-2024, 07:05 PM   #4
Mark114
Mark114's Avatar
Drives: 2016 2SS Convertible
I found a Whipple hood vent for the 5th Gen. Is this what you’re asking about?
https://www.americanmuscle.com/whipp...cf-cam-hd.html
Old 02-07-2024, 08:49 AM   #5
Turbo_Jet
Drives: 2019 ZL1
A few months ago, Whipple "quietly" announced their 3.0 kit release specifically for the Gen6 ZL1 & CTS-V3 crowd (I say this since they barely mentioned it in one of their IG post). It's now offered in their Website, however, it states that for the ZL1 an aftermarket hood or insert is needed for proper clearance. They do offer a Carbon Insert for $350. Pretty sure this is what the OP is referring to...
Turbo_Jet is offline   Reply With Quote
Old 02-07-2024, 10:38 AM   #6
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
I think Whipple has an option for one on their website... I was on my phone when I saw it, so I could be misunderstanding... I wonder if they're talking about the panel, UNDER the hood, because that's where contact was in the 2.9 kits, and it's close enough to Maggie 2650s that even port plates will cause interference. Edelbrock 2650s hit right out of the box and require cutting the actual hood panel, so I'm wondering if the 3.0 Whipple may hit on the pulley end or the rear of the hood, just in front of the cowl...
I thought they were talking about a raised CF extractor, which I'd be all over, lol. It doesn't look that way though. They don't volunteer a lot of good information...
Old 02-07-2024, 12:10 PM   #7
Gr3m27
Drives: Camaro
Yep, this.
"...Whipple’s groundbreaking 3.0L Gen 5 Supercharger System! Designed meticulously for your Camaro ZL1 or CTS-V..."
"**Special Note for Camaro ZL1 Owners:** To ensure proper clearance and optimal functionality of the supercharger system, the Camaro ZL1 requires the installation of the Whipple Carbon Fiber Insert or an aftermarket hood."
From what I can find online it is just a bit taller than the stock one and more squared off but I have not see it on a car and that is what I was looking for.
Just checking with the community, probably not going to change my mind on a Whipple over Magnuson.
Old 02-07-2024, 12:55 PM   #8
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
Yep, this.
The fitment problem, generally, is not to the hood. There is a panel, under the hood, that helps give the CF insert some support. It is THIS panel that usually requires trimming (and sometimes the rear part of the hood panel, itself, too). I must be confused.
