Go Back   CAMARO6 > CAMARO6.com General Forums > Regional Sections > USA - NY / NJ / PA
Old 02-05-2024, 01:34 PM   #1
TobyinNJ
Drives: 2018 Camero SS 1LE
Engine Rebuild in NJ
My 6.2 LT1 "spun a bearing" according to the dealership after an oil pump failure. I guess I need a bottom end rebuild or replacement. Who do you guys recommend going to? I may upgrade the internals at the same time, but will probably maintain the displacement.
Thanks for any advice.
TobyinNJ is offline   Reply With Quote
Old 03-31-2024, 10:12 AM   #2
LiqTenExp
LiqTenExp's Avatar
Drives: 2017 ZL1
Where in NJ are you. Tune Time Performance is in Lakewood, you could check them out.
Old 07-15-2024, 05:02 PM   #3
Lux
Corvette Guy
Drives: 2015 C7
I know this is a bit late but Case House Performance in Brick. If you can pull the engine yourself then Ryan's Custom Machine in Matawan.
Lux is offline   Reply With Quote
