Old 02-05-2024, 01:03 PM   #1
nissandr
Drives: 22 camaro 1le rapid blue
gpi lt nfc camshafts
anyone running one of these gpi no fly cut camshafts? if so what's your thoughts on it
nissandr is offline   Reply With Quote
Old 02-06-2024, 07:15 AM   #2
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Good cam for the track with proper setup. Will want more compression. Needs large converter or steep gears for a manual. Manifold that will make power to 7500rpm and a good valvetrain setup. Not something I would run in a frequently driven street car.
Old 05-26-2024, 03:25 PM   #3
JST1FIX
JST1FIX's Avatar
Drives: 19 SS 1LE
Running one in my 19 1SS 1LE. I am running Katech ported heads, MSD intake, Soler ported 95mm TB. It makes good power up high. I think to take full advantage of the cam I need to switch to a hi ram intake and pull more RPM.
JST1FIX is offline   Reply With Quote
Old 06-03-2024, 02:59 PM   #4
bessen13
Drives: 2020 Camaro SS 1le
Do you have any dyno numbers?
bessen13 is offline   Reply With Quote
Old 06-06-2024, 03:40 AM   #5
NYblack1le
Drives: 2018 1SS 1LE
Why the NFC cam? What’s your plan with the car? Is e85 attainable where you live ?
NYblack1le is offline   Reply With Quote
