Old 02-03-2024, 01:21 PM   #1
NiickySaz
NiickySaz's Avatar
Drives: 2023 Camaro 1LT V6
10L60 to a 10L90 is it possible?
Hello Gen6 owners.
Like everyone else I have a list of things I'd like to set out for the year. One being to supercharge my LGX(keeping stock exhaust). Chances are very slim but, worse case scenario; if the transmission goes, could I have a 10L90 installed oppose to the current 10L60? Yes, I am still under warranty(put <400 miles a month on the vehicle, less during the winter) but just sort of wondering if it's possible.
Thanks!
NiickySaz is offline   Reply With Quote
Old 02-03-2024, 02:41 PM   #2
Bumbleboy92
Long hauler
Bumbleboy92's Avatar
Drives: 2022 Camaro 2SS 1LE
I’ll say it’s probably not worth it, the fastest 6th gen v6 is on the 8L45 I believe
https://www.camaro6.com/forums/showthread.php?t=546955
And he once upon a time asked a similar question
https://www.camaro6.com/forums/showthread.php?t=523595
His last update was the engine itself hitting close to its limit rather
2016 1LT v6
- Totaled
Happiness: Infinite
Bumbleboy92 is online now   Reply With Quote
Old 02-03-2024, 03:21 PM   #3
NiickySaz
NiickySaz's Avatar
I'm not trying to be faster than anyone. Just durability being a factor. I'll be thrilled if I get 350/360whp
Old 02-03-2024, 09:08 PM   #4
DevilsReject97
Nightmare
DevilsReject97's Avatar
Drives: Your mom crazy in bed
The 10L90 is the A10 transmission for the ZL1. Pretty sure that this is not a direct bolt-in swap type deal, especially for the V6 model.
Might be different if you had the SS, since they use the 10L80 already (for specific years anyways).
Old 02-03-2024, 10:05 PM   #5
NiickySaz
NiickySaz's Avatar
That makes sense, mine is also the A10, I just wanted to see if it was capable to mount to a V6 I just figured it's from the same family, just has more potential to handle more power( God forbid if mine goes)
Old 02-03-2024, 10:32 PM   #6
DevilsReject97
Nightmare
I know the cases are different, but the 10L90 is specific to the ZL1 only. Different ratio, different performance, etc...
There are lots of parts that are from the "same family" but don't swap in/out easily. From what I can tell from the outside, they are not directly swappable. With work, it's probably possible..
Old 02-03-2024, 11:38 PM   #7
LT4Greg
LT4Greg's Avatar
Drives: 2017 Camaro ZL1 Coupe
To the Op, just get your original trans rebuilt if needed after the mods done to the V6.
