Old 02-02-2024, 02:49 PM   #1
cbooms23
Drives: GMC Sierra 1500, Chevrolet Camaro
Do manual SS have AFM?
I have a 2023 SS with the stick and I know it has the skip shift and does not have the AFM, but what do we know about the actual internal differences if any?
cbooms23 is offline   Reply With Quote
Old 02-02-2024, 02:52 PM   #2
JamesNoBrakes
JamesNoBrakes's Avatar
Drives: 2SS 1LE
No
2018 2SS 1LE
2023 Colorado ZR2
2022 Stinger GT-line AWD
JamesNoBrakes is offline   Reply With Quote
Old 02-02-2024, 03:03 PM   #3
cbooms23
Originally Posted by JamesNoBrakes View Post
No
No internal differences? All software? no software=less problems?
Old 02-02-2024, 03:04 PM   #4
Hostile_1LE
Hostile_1LE's Avatar
Drives: 2020 Camaro SS 1LE | Satin Steel
All 6gen camaro's have the AFM lifters and AFM valley cover oil manifold thing, but m6 cars have the AFM tuned out. So all the hardware is there in a manual, it just doesn't activate.
HCI | GPI SS3 | E85 | xxx whp \ xxx tq
Hostile_1LE is offline   Reply With Quote
Old 02-02-2024, 03:07 PM   #5
Bumbleboy92
Long hauler
Bumbleboy92's Avatar
Drives: 2022 Camaro 2SS 1LE
The only hardware difference between an auto and a manual is the manual exhaust does not have the AFM valves in it. Otherwise as Hostile said, same hardware just turned off
2016 1LT v6
- Totaled
Happiness: Infinite
Old 02-02-2024, 08:03 PM   #6
david_acm
david_acm's Avatar
Drives: LT1
Is the AFM hardware benign? Any reason to replace them?
david_acm is offline   Reply With Quote
Old 02-02-2024, 10:18 PM   #7
m6-lt1
m6-lt1's Avatar
Drives: 2023 Chevrolet Camaro 2SS 1LE
When GM motors fail it tends to be due to the afm lifters. Not implying that high percentage of them fail but when they do it typically starts as a lifter issue.
Current: 2023 2SS 1LE
Prior:
2016 Camaro 1SS
2007 Mustang GT
2008 Civic Si
m6-lt1 is offline   Reply With Quote
Old 02-03-2024, 09:02 PM   #8
DevilsReject97
Nightmare
DevilsReject97's Avatar
Drives: Your mom crazy in bed
The lifters are the same but AFM is what generally causes the lifter failure, not the manual transmissions or the supercharged motors (ZL1).
Can the lifters still fail? Of course, just as a timing chain or something else could.... but the automatic trans cars (V6/SS) are where the problems generally occur.
Old 02-04-2024, 05:27 AM   #9
Gen6cyl
Drives: Chevy Camaro 2021 ,rs, v6, manual
A lgx can not have valve lifter problems. Can a lgx manual transmission suffer from afm hardware, I don't know.
Gen6cyl is offline   Reply With Quote
Old 02-04-2024, 08:02 AM   #10
Number 3
Hail to the King baby!
Number 3's Avatar
Yep, hard to have a failed lifter in an engine without lifters.
Funny thing is the V6 in my LaCrosse was invisible for AFM. Start stop was as good as any other OEM I’ve experienced. But the V8 in the G8 and Camaro has always been passable to horrible. The SS didn’t have AFM but I believe I paid $1,200 for the gas guzzler tax.
Old 02-04-2024, 05:50 PM   #11
DevilsReject97
Nightmare
Actually, the LGX has AFM. The LFX did not, nor did the LLT.
The LGX and LGZ are considered to be a newer generation version of the GM 3.6 V6 engine. It featured big changes including different block architectures and bore sizes. This version of the engine supports features like cylinder deactivation and updated variable valve timing.
Active Fuel Management (cylinder deactivation) and Auto Stop-Start system generate fuel savings of 9 percent compared to the 3.6L V6 LFX
Old 02-04-2024, 05:56 PM   #12
DevilsReject97
Nightmare
Most states still ding the Camaro as a gas guzzler even with AFM, but I'm going to assume yours was a manual as that will always get dinged.
Old 02-04-2024, 08:00 PM   #13
Number 3
Number 3's Avatar
SS Sedan. GG Tax was federal so I’m not sure what states added additional taxes??
Old 02-04-2024, 08:25 PM   #14
DevilsReject97
Nightmare
Usually cars that are imported get hit with the GG tax when it doesn't hit at least 21.5 MPG average. I had forgotten this was federal not state.... but I do believe that some places like California do have additional taxes.
