![]() Drives: 2018 ZL1 1LE Join Date: Jan 2024
BMR upgrades.
Hi everyone,
6th gen SS M6. I upgraded some suspension parts to BMR. Cradle bushing lock out kit and lower trailing arm. Ever since, when I come to a stop slowly I can hear slight clunk noise. Only when coming to a stop slowly. Otherwise quiet. I had shop do the install. That shop is generally real good place for mods install. In the spring will be returning to shop, but just wondering if anyone experienced this or know the issue? Thank you. |
![]() ![]() ![]() ![]() ![]() Drives: 2020 Chevy Camaro ZL1 Join Date: Apr 2023
Check this out, see if it sounds familiar? The reason I suggest this is I can’t see the lock out or trailing arms being the issue, unless they didn’t properly tighten bolts
https://www.camaro6.com/forums/showt...php?p=11383516 |
